How much rust is too much?
My post about possibly buying a 72 GMC that has some rust issues and some of the replies, has me asking a couple of questions, how much rust is too much to consider restoring a truck and what is a desirable configuration that would make you fix more rust than you normally would?
I have seen quite a few posts on restorations here where people are replacing the normal things like rockers, cab corners, cab supports, and outer floor pans as well as the more difficult ones such as the entire floor, roofs, inner roofs, and firewalls. Beds don't seem to be the real deal killers as they don't usually seem to rust as bad as the cabs and it's easier to find mostly rust free beds vs rust free cabs. Obviously the least amout of rust is desirable but for the ones here that have done or had done extensive rust repair, what was your motivation to buy one with a lot of rust or fix one that you currently owned instead of finding one with less rust to fix. Thanks. Wayne |
Roadtrip!
![]() Join Date: Feb 2003
Re: How much rust is too much?
To answer your initial question, this is too much rust...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Member
By the time I got my truck the rust was pretty bad, but the truck was originally my grandfathers and it had a lot of personal value to me. I've owned it for close to 20 yrs now and restored it twice. The second time I realized how hard rust was to fix. I replaced both front fenders, one door and the bottom of the other. In short.... I hate rust!!!! Unfortunately it's a fact of life here in Florida.
Posted via Mobile Device But at least my cab was in pretty good shape, that seems to be the most expensive area to fix. Bolt on parts are rather cheap and easy to find Posted via Mobile Device Posted via Mobile Device
1970 CST LB Fleetside, 402 BB, PS, PB,AC 1968 Firebird 400 conv. 1965 Chris Craft 17' wood ski boat (SN #0001) |
I got this 68 c10 for almost nothing. Next morning I found all this rust problems. I gave it away to my buddy. Surface rust is ok but no holes.
How often do you guys actually find this body style of truck with no rust holes that has not been fixed in the past?
Wayne |
Cruzin
Just depend on what you want to fix, my truck got rockers, couple cab supports, front cup on one fender, drivers side lower half of door was replaced, cab corners, couple floor patches. Nothing to bad some i had done some i done i have a 59 project comeing up and i plan to do it all myself it need more work than i ever done but thats how you learn!!!
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
![]() Join Date: Feb 2001
I would say this is to much rust
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
wasnt that white truck restored? and looks very nice now? i could be thinking of a diff. truck though...
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
To me rockers and cab corners are fine on the cab, and anything that you can unbolt is good but the price of the truck to start with would play a big part of how much is to much I guess.
Still trying to deciede on my 70 what's going to happen with it as it will need a bed and doors but the rest is the normal rust for around here, but a bed and 2 doors can cost.. Posted via Mobile Device |
#11 | |
Guess I'm lucky. My body man charged me 2 hours to repair the rust in my 72. A quarter size hole in one rocker and a nickel size hole in each door. Patch panel and lead. No plastic.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#13 |
#14 |
What is the average cost to replace rockers, cab supports, cab corners, and the entire floor?
I guess I'm used to cars where you have floor, trunk, qtr panels, and possibly rockers that many times need fixed. My 70 Monte needed both qtr panels replaced as well as the bottom half of both front fenders done. It also had to have the lower part of the rear window channel rebuilt. One of my floor pans still has a crack in it that needs to be fixed. I guess my point is, is that I've seen a lot of cars redone that needed way more rust repair than a lot of these trucks do yet people seem to be hesitant about having much rust fixed on the cab. That white 4x4 GMC is worse than I have personally seen and I agree that I wouldn't consider it a canidate for a restoration even though it's a 4x4. Thanks again for all of the input. Wayne |
#15 |
Rusty Nuts
this one looked like this but now it looks like this. I guess eveybody has different outlooks on what is too much rust.Although there were a couple of pictures posted the even i would not tackle.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
#16 | |
lol. do you have a welder? do you want to take the truck apart and get dirty? really it depends on your skillset and time/$. anything (almost) can be fixed, but unless you can do it yourself at some point it becomes easier to replace the cab. esp on these types of vehicles where rust free parts are still around. very different when you're talking about a prewar ford or something more rare. I've known folks to replace insane amounts of rare cars, because that is their only choice.
Current: 1971 K10 lwb Past: 1972 c10 lwb 1969 c10 swb 1977 c10 lwb more old jeeps than I want to remember! |
#17 |
member #16
![]() Join Date: Dec 1999
70 cst, I think that truck was on classic heartbeat years ago. the guy inherited it when his brother passed. It was restored to like new condition. maybe Wes remembers it.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 08-27-2012 at 04:09 PM. |
#18 |
Florida Edition
![]() ![]() Join Date: Oct 2010
I personally won't tackle a cab that needs cab supports and major roof repair (I don't have the time or talent). Inner and outer rockers, cab corners, small roof, cowel and floor repairs are all managable for me. I like to keep the metal repair on a cab in the $1500 range (not including doors) or less.
Now if it's a rare and/or super desirable unit I'll consider spending more. Remember they made millions of these cabs so good ones are still out there. You also have to factor travel or shipping costs if thats what it takes to find a solid one. In my opinion a nice solid a/c deluxe cab and doors (requiring no metal work)is worth $2000 to $2500....here in Florida.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#19 |
bbadfred
![]() Join Date: Mar 2008
#20 |
Moderator
![]() Join Date: May 2007
Take a trip out west and pick up a rust free truck. You will be $$ and time ahead versus fixing a rusty one, unless you have lots of time and like to weld.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
#21 | |
Wayne |
#22 | |
The Niner
![]() Join Date: Nov 2010
This is what I did... no regrets whatsoever.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
#23 |
There have been some very reasonably priced trucks on the Las Vegas Craigslist.
I picked up my 72 K20 for under $3500 delivered to my house . It just turned over 66,000 miles. It had sat for over 10 years and I had a lot of dried out seals but, all of the rust on the truck wouldn't cover a paper plate. It has some dents but very little rust. Most recently I purchased a 72 C20,402 BB,TH400,AC cab,power steering and brakes, front stabilizer, original hubcaps, overload springs,AM/FM with MP3 input, near new dual exhaust, and a tool /stowage compartment,,,,,,,,,,,,,$2k delivered to Iowa. Less rust than the K20. When I started looking for a decent box I was looking at a grand, or there abouts, for a straight box. A complete cab floor delivered will run around $4-$600 plus the labor to install it. I got a whole truck , that I could drive, for $2K,,, that's a no-brainer. Now keep in mind, I bought 3/4 ton trucks, both long beds. A short box will cost considerably more because of the demand. A lot of people don't want a 3/4 ton because they want a daily driver that will seldom pull a trailer, haul a heavy load and desire a softer ride. I wanted 3/4 ton to use. But keep in mind,,a 3/4 ton cab and box are totally interchangable with 1/2 ton. And if the desire to have a short box is on your mind,, there are several members on here that have cut down a long box to a shorty. Have a great day !! Tom |
#24 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#25 | |
Wayne |
