Old 08-27-2012, 10:28 AM   #1
skeeterbug
skeeterbug's Avatar
(2) weld wheels
I purchased these two used rear wheels from an individual last spring and was not able to use them on my rear disc setup. They are weld draglites 15 x 10", 5 x 5 bolt pattern, w/ 5" bs. They are in good used condition not bent, cracked, or modified in any way i just cannot use them. $200.00 plus the ride. Name:  weld wheels.jpg
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Old 08-28-2012, 09:07 AM   #2
skeeterbug
skeeterbug's Avatar
Re: (2) weld wheels
bump
2013 best 7.39
2014 best-7.38
