GMC grill
How do you get rust from a grill. Sand, polish, rechrome, paint, or buy after market.
Active Member
![]() Join Date: Jul 2007
Re: GMC grill
All of the above.
To be more specific, it all depends on how bad the rust is. If it can be sanded smooth or media blasted and repainted that would be a cheaper option. I checked into chroming mine (painted now) and found out it was going to cost about the same as buying a new chrome one so it was basically a toss up.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Hybrid67
Re: GMC grill
new ones run upwards of 400 not shipped. Depends on the level of detail you want out of your finished product. I painted mine til I can convince the wife to part ways with half a house payment!
Keep em' Running! ![]() All show.....no go ![]() |
2WD Jimmy
![]() Join Date: Mar 2005
Re: GMC grill
If you have a good OEM, I'd rechrome it if the chrome shop says they can do it justice. I have a repop, and I am still going to rechrome it because the chrome on it is just o.k. It also did not fit near as nice as the original.
By the way, a 'chrome' shop which will go unnamed ruined the original. Chrome shops are not created equal, so make sure you get reliable recommendations. Posted via Mobile Device |
Location: The World's Most Famous Beach...Daytona Beach, FL
Re: GMC grill
I use 00 steel wool....lots of "elbow grease" and follow up with 3M finishing compound using small buffing wheel on a variable speed drill.
Unless the rust has began to rot thru....I can get a "like new" finish.....even the pits of the rust origination can be hard to see once done. |
