20' Daredevil (Ret)
![]() Join Date: May 2003
I recently had to remove the original floor pad material -- a thin lightweight white foam against the floor, topped by a thicker, heavy, dark material that I guess must be sound deadener / heat barrier. They're both in pretty rough shape and I'd like to replace them.... but what with? It's just a rough work truck and I don't need anything fancy or expensive, just something to go under a rubber mat. Is the OEM type padding still available? Or is there something better out there? Thanks guys.
The Older Generation
Re: OEM-type floor padding?
I just put the jute padding under my rubber mat tonight. You can buy it separate. I think it's about 15 bucks. LockDoc
![]() Join Date: Aug 2008
Lowes and home depot sell some silver radiant barrier that I think is intended for garage doors. That works pretty good and is fairly cheap.
Posted via Mobile Device |
