05-25-2003, 02:21 AM | #1 |
cracked crankshaft
this is my latest problem in my string of destruction, after breaking an axle first time out, now this. got it back together from the axle incident with new moser custom alloy axles, bought a new 750 double pumper, put on a fuel log and 1/2" line from the regulator to the log. took it for about a 2 mile ride by my house and heard it start making noise, threw it in nuetral and wathced the oil pressure drop to about 10 lbs!!!!. took the motor out and the guy that built it took it apart and found the crank is cracked, oh well i guess its gettin a scat 9000 crank and a solid cam while its out. think the solid will make a big difference??? Thanks, Devin
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112 67 nova numbers matching 327 4 speed 13.6 @ 102mph 70 longhorn c-30 402/4 speed 70 c-10 swb 402, muncie 4 speed 94 s-10 350/th350 3:73 posi 71 c-20 402/th400 towrig for racetruck. 72 4wd lifted on 35's 72 350/3 speed winter beater |
05-25-2003, 08:45 AM | #2 |
solid cams are alright if you like doing the extra maintenance
