08-28-2012, 12:21 AM | #1 |
53 chevy suspension advice
The bottom of the front fender opening at the center is about 28 1/2" with 15" wheels & 205/70 tire. I think I want to go 3" lower.
Is it a better idea to go with a 3" drop axle and have some more flexability with lowering leafs later or should I just put some 3" lower leafs and keep the axle stock? |
08-28-2012, 10:40 AM | #2 |
Re: 53 chevy suspension advice
I'd go with the dropped axle. Unless one of the mono leaf springs gets a guy 3 inches I am not sure there are new springs that give a guy a total 3 inch drop out there but that isn't something that I have made a study of.
http://www.droppedaxles.com/ aka Sids is the go to place to have your parallel leaf axle dropped correctly. A guy can either send his core in or pay their core charge. Removing leaves to drop the truck isn't a very good idea even though it gets the truck down as the leaves keep on sagging until the axle bottoms out on the frame after a period of them and my own truck is a prime example of that. |
08-28-2012, 02:46 PM | #3 |
So new leaf springs that say they give you 3" probably won't actually give you that much.
Replacing leafs to get 3" inches just seemed alot easier and cheaper than buying a 3" dropped axle and the related steering arms, drag link, ect..... |
08-28-2012, 06:31 PM | #4 |
Springs are always iffy on drop or lift. there are too many things that change the height. Engine /transmission weight and placment aditonal frame boxing and added crossmembers etc. also drop springs can cause clearance problems.
I feel if you are going straight axle the dropped is the way to go. |
08-28-2012, 11:38 PM | #5 |
Does installing a dropped axle result in bump steer? Sid has modified steering parts, I'm sure they are required for clearance.... but what about quality of drive? What mods exaggerate bump steer?
