55 2nd Series LS1
has anyone installed an ls1 in their trucks if so i would like to see what everyone is doing as far as radiators, fuel pumps, etc.
'55 Chevy PU 2nd Series '97 Chevy Silverado XCab '13 GMC Sierra ![]() |
Re: 55 2nd Series LS1
Don't know if you mean LS1 specific or just LSx in general...
There's some good stuff in the LSx swap part of the board here... http://67-72chevytrucks.com/vboard/f...prune=-1&f=206 I have a 5.3 / 4L60E and my build thread is in my sig. Others who have done or are doing this type of swap... blackdiesel , Kabwe , Kim57 , JML55 , and several others, but most on here are the 5.3 6.0 or LS2. If you search the site and find the builds you may find more info.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
I'm building my second LSx swap right now. I just used an aftermarket alum. Radiator from Coolcraft. So far no problems. You can use an internal or external fuel pump. Best bet is to go to ls1tech.com in the Hybrid sub forum and look at some of the builds. There are some that are stickies and answer most questions. I'd try to get a manifold that only has a fuel supply line. Some have supply and return so you have to run two lines to the front. Manifolds are cheap and pretty much interchangeable between all motor types.
'59 Big Window Fleetside |
