05-25-2003, 03:12 AM | #1 |
Ot:but anyone think a 500 caddy could be put in a nova?
that'd be sick ultimate sleeper lil puke green nova all stock looking with ralleys and a quiet exhaust...
05-25-2003, 08:45 AM | #2 |
With a big enough hammer and a torch anything is possible, but is it worth the effort. Considering some of the nova's came with 427's, Id say it is easier than putting a 454 into a Yugo.
05-25-2003, 09:32 AM | #3 |
Psycho-billy Member
I believe it can be done without much trouble and have been kinda thinking of doing that with my 500 instead of putting in my truck. There's a guy on the MTS message board that's running a 500 in a Mustang (87-93?) and another that has one in a Thunderbird T-Coupe. I would think the Nova would have more room than either of those cars.
'72 C-10 350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers. Support your community, support yourself. Buy local, buy American (or Canadian). |
05-25-2003, 09:44 AM | #4 |
its all about the +6 inches
Heck, one of the guys on the MTS board has shoe horned one into a Datsun 280Z!
Here is a link to there board. http://www.webdeveloper.com/animatio...files/sexy.gif I go as andy in Ohio, but don't post too often. |
05-25-2003, 11:49 AM | #5 |
Registered Cruiser
I don't think the nova body would handle the torque
I intend to live forever. So far, so good. |
05-25-2003, 12:20 PM | #6 | |
Psycho-billy Member
If the Mustang (uni-body) is handling it, the Nova will.
05-25-2003, 01:01 PM | #7 | |
Who's in CHARGE??????????
As for the QQQ of a caddy motor going into a Nova there is a kit out there, I seen it in Hot Rod I believe. if I see it again I'll post the name of the company.........joe
Send a card to a soldier in Iraq My Music PlayList Large Marge Donate Blood,Plasma,Platelets & sign your DONORS CARD & SAVE a LIFE |
05-25-2003, 02:53 PM | #8 |
If a nova handled the 427, then it should handle the power of a 500 caddy. You would want to tie the frame in, especially before you run slicks.
05-25-2003, 03:46 PM | #9 |
of course the nova will handle it. i have seen nova running 10's on basically a stock suspension
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
05-25-2003, 03:56 PM | #10 |
Remember, the nova was basicly a first gen camaro underneath...and I have seen a few 67-69 camaros with 500s in them.
05-25-2003, 11:54 PM | #11 |
OOPS! That link isn't quite what I intended... here is the right one, I hope. ;0 http://www.hwforums.com/2089/
05-26-2003, 11:15 PM | #12 |
Here is a camaro that has a 500 in it...
And a link telling about it all. http://www.carcraft.com/featuredvehicles/66358/ |
05-26-2003, 11:31 PM | #13 |
THE QUICKER FIXERUPER
I saw a 500ci cad in a chevet
05-26-2003, 11:42 PM | #14 |
heh heh heh...that was sweet huh?
05-27-2003, 12:10 AM | #15 |
how bout a 500 caddy mtr in a Metropolitan , hell the guy sat in the back seat.joe
05-27-2003, 12:46 AM | #16 |
Well, Whoop-dee-do!
If you are wanting to put it in a later Nova with the steering gearbox up front it will fit pretty easily without column shift & using an Eldo pan. You will need to fab up a pair of steel plates to extend off the crossmember for the Cad's motor mounts which will pretty much be completely hanging in front of the crossmember. The plates are simple to make & just weld them in. You will probably need to replace the fat ugly joint on the steering gearbox shaft at the column end for manifold clearance. Use RWD exhaust manifolds. BBC headers will adapt with some choppin'.
As for the older Nova with rear mounted steering gearbox, for all practicality, FORGET IT. I tried it with a '73 Apollo which is the same as a Nova (Buick clone). It sat in nicely without an oilpan or left exhaust manifold. I figured I could c-notch the oilpan for drag-link clearance or make a drop drag-link easy enough. But the real problem was the left exhaust manifold. There is NO WAY it will clear the steering gearbox. I even tried a manual box for more room. With the engine centered, the rear exhaust port lines up perfectly with the box and about 1/2" clearance. There would not even be room to fab up headers without some serious engine offset to the right side. Even then, it would be tight & probably need the L.R. tube smashed in. It looked like the only way for a decent fit was to build a sub frame from scratch & use a Stang II rack or something. Later on I wondered- will a later nova stub bolt into an earlier body? ---------------------- 78 regal 500 cad/switch-pitch 400 2.73 posi ran best of 14.00/96mph BONE STOCK (not mine anymore) 80 GMC K-20 mild 500 cad/switch pitch 400-205-4.10's. Might be for sale soon 72 Chevy K-20 stock 500 cad/th350-205-4.10's eaton locker rear trac-loc front 88 Chevy V-30 dually camper special 454 TBI/4 speed-205-4.10's dana power-locs going in F/R soon 88 Chevy C-30 single wheel e-cab 454 TBI/TH400-4.10's in a 70HD. Anyone have 3.42's & carrier for this??? |
05-27-2003, 07:59 PM | #17 |
Hmmm, interesting. I asumed it would be fairly easy since ithe under pinnings are so much like the fist gen camaro.
That DOES sound like alot of work. |
05-27-2003, 08:44 PM | #18 | |
05-27-2003, 11:30 PM | #19 |
Binder Rep
My friend used to have a '63 Nova (didn't look like anyone was considering those). He had a built 305(?) or so from a trans am in that car... and *that* motor was more than enough. With the factory 2.54 rearend he had that car over 150 mph before... and then he only stopped because he scared himself to death doing that speed on a 2 land country road with a 45mph speed limit. That car could really move. Only thing faster than that I've seen in person is the buick regal he traded the nova for. Built 455 that wanted race gas but would run on premium with octane boost. Dyno'd at over 600 hp at the wheels (premium with boost, gained at least 50 hp with the race gas). That car had a 2.73 rearend.
