20' Daredevil (Ret)
![]() Join Date: May 2003
Another dumb question, but this is new stuff to this old guy. When you re-install a high hump, what do you use for sealer? Is the OEM stuff still available at GM dealers (or elsewhere) or is there something better?
C/10 junkie
Re: Seam Sealer for Tranny Hump?
Would like to know as well.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
The Older Generation
I used ROPE CAULK. you should be able to get it at your local hardware store. LockDoc
20' Daredevil (Ret)
Thanks, Leon! I'll see if they have it.
What?
I just used a high temp silicone.
It was not the type one uses as a gasket sealer, it was a type that stays some what tacky. I have had to remove the hump twice since laying down a large bead, and all I do is mold it back into a bead and then set the hump back down and it seals up again just fine. I then just take a rag and wipe away the excess that squeezes out. Can't remember the brand, but it comes in a large tube for a caulking gun. The color is graphite.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
I used seem sealer for steel roofs. it's a butal tape that comes in a roll with a wax paper removable backing. It stays soft forever and conforms to every contour. Clean and easy to use and only cost about $5 for a 20 ft roll. You can get it at any large hardware store that sells steel roofing. If you ever need to remove the hump it will come right up as it doesn't harden.
http://smg.photobucket.com/albums/v655/aaronhero/ |
20' Daredevil (Ret)
Hmmmm, I have access to something that sounds identical, at an unbeatable price.... if it's still there. If not, I have a couple other great suggestions. Thanks, guys.
Active Member
![]() Join Date: Feb 2012
I use 3M Windo-Weld Ribbon (3/8" X 15' round bead). Its very sticky, water proof, part nummber 08612.
What airspeed said bought mine from napa/rebies works real nice stays soft oh and it's the3/8 thickness
Posted via Mobile Device |
Butyl Tape or window weld works well. Silicone sealer will attract and trap moisture causing rust issues and should not be used on body surface.
20' Daredevil (Ret)
Well, my local hardware didn't have a lot to choose from. I ended up using a complete 10.5 oz. tube of gray Big Stretch sealant. It sets up firm (not hard) and retains some flexibility, so it can bend & stretch without cracking or breaking.
![]() Join Date: Jan 2007
Butyl tape for sure.
I bought a large roll from the local marine supply for about $7. It's reusable, waterproof, somewhat firm, not silicone, and cheap. Guys use it on bolts to seal their deck hardware and window ports from leaking through... so it's gotta work!
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
#13 |
I built it
i used liquid gasket maker on mine and it seals up good
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
