Old 08-28-2012, 09:08 PM   #1
ohmaback
drop spindles
hi again, does anyone make a drop spindle for the original drum brakes? looking for 2" or 2 1/2".
ohmaback is offline   Reply With Quote
Old 08-28-2012, 09:18 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: drop spindles
no.
Keith
Convert to disc brakes.
Old 08-28-2012, 09:20 PM   #3
Bazooka
Keepin it old school
Bazooka's Avatar
Re: drop spindles
Would be nice if they did for budget builds like mine. Converting to disk brakes is a great upgrade though.
Bazooka is offline   Reply With Quote
Old 08-28-2012, 09:23 PM   #4
ohmaback
Re: drop spindles
bummer ,i know disc's are better but......... guess I'll just have to have more yard sales to earn the $'s. Do any of the D/B kits fit the stock wheels 65 c10
Old 08-28-2012, 09:50 PM   #5
jaredbaker919
Re: drop spindles
I got the same dilemma. The only thing I could find are DJM's 3" drop lower control arms. Which seem to have mixed reviews. Disc brakes turn into a really expensive upgrade when you end up having to get new rims.
jaredbaker919 is offline   Reply With Quote
Old 08-28-2012, 10:16 PM   #6
Solo2002
Solo2002's Avatar
Re: drop spindles
You could always use wheel adaptors to go from 5 lug back to 6 and salvage parts aren't really that expensive you can get every thing from the booster to the lug nuts for at or under $250 well around here anyway I have $200 in mine then about $150 in new rotors calipers and pads so it's not out of reach
1966 C10 short stepper KMHK
Solo2002 is offline   Reply With Quote
Old 08-28-2012, 10:50 PM   #7
mano
mano's Avatar
Re: drop spindles
They make a 6 bolt rotors. The stock wheels won't clear the calipers. You need a 70s-80s 4 wd 6 bolt wheel, if you want to be 6 bolt all the way around. or just get a 2wd 5on5 wheel for the stock 73-87 5 bolt. Check craigslist for somebody parting out a old 73-87.
mano is offline   Reply With Quote
Old 08-28-2012, 11:08 PM   #8
CRGRS 66
CRGRS 66's Avatar
Re: drop spindles
Scott's Hot Rods in Cali has a great deal on 2.5" drop spindles, rotors, calipers, pads, hoses, hardware, booster, MC, prop valve, he is a vendor on here, check him out, you would be surprised how economical it is to do this swap, and the spindles go right on your stock ball joints. The cost is not a whole lot more than a brake job at a shop would cost. Scott's is a vendor on here, should not be hard for you to find.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
