Old 08-29-2012, 07:31 AM   #1
Jayschevy
Can I run my 71 without the fan shroud?
I have a 71 C10 and for some reason my fan blades hit my fan shround sometimes. I've tried to realign and retighted the shround with no luck. My question is can I just run the truck without it without over heating my truck?
Jayschevy is offline   Reply With Quote
Old 08-29-2012, 07:34 AM   #2
jjzepplin
jjzepplin's Avatar
Re: Can I run my 71 without the fan shroud?
Check your motor mounts. They may be bad.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-29-2012, 07:37 AM   #3
Jayschevy
I forgot to add that my truck is bagged. When I layout the blades hit on the bottom of the strouud and hit on the sides/top when I air it up.
Can I run without the stroud?
Old 08-29-2012, 07:42 AM   #4
502ms
502ms's Avatar
My c10 has electric fans, no shroud, no overheating. Didn't have issues when I had the belt driven fan either
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 08-29-2012, 07:43 AM   #5
502ms
502ms's Avatar
Jay, any pics of your truck?
Best Regards,
Leon M.
Old 08-29-2012, 09:39 AM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I wouldn't advise it, but some guys run without a shroud and get away with it. If you can't solve the interference problem, I'd switch to electric fans.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 08-29-2012, 12:14 PM   #7
MARKDTN
I agree
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 08-29-2012, 01:34 PM   #8
Gobbles
Gobbles's Avatar
I run my 454 without a shroud, never had a problem. My thermocouple works and the temp is always down at the norm.
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
Old 08-29-2012, 01:48 PM   #9
LockDoc
The Older Generation
LockDoc's Avatar
All the more reason to check the mounts like jjzeplin said, unless you have installed new ones lately... Motor "and" transmission. You can certainly try running without the shroud and if you have heating problems re-install it.
LockDoc
Leon
Old 08-29-2012, 01:51 PM   #10
davepl
davepl's Avatar
Anything's possible, of course, but if you remove the shroud you significantly increase the chance of overheating, particularly at low vehicle speeds.
Without a shroud the fan will pull air from the side, not through the rad (the path of least resistance... the shroud is there to -force- the air to come through the rad).
Even electric puller fans -should- have a shroud otherwise you only "cool" the small portion of the rad surface where the fan blades are, so it's like having a tiny rad.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-29-2012, 03:18 PM   #11
Dano69c10
Dano69c10's Avatar
I've run without a shroud with no problems since 1978; BTW, I live in SoCal where there's major traffic and major heat.
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 08-29-2012, 07:46 PM   #12
54Caddy
GM Addicted
54Caddy's Avatar
My dads 68 has a small 6cyl shroud or if you should even call it a shroud, basically just a fan gaurd. He has a v8 in it with no problems in this 100+ valley weather.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 08-30-2012, 10:55 PM   #13
rico7769
Hybrid67
rico7769's Avatar
I'd run the shroud. Even if you have to mod something up to force the air through the radiator. I've heard positives and negatives but more lean toward keeping it on. Wouldn't want to overheat because of a small inconvenience.
Keep em' Running!
All show.....no go
rico7769 is offline   Reply With Quote
