![]() Join Date: Nov 2002
Which would be easier, lengthing frame or converting stock to 4wd?
I'm in a dilemna on what to do next with my 71 Longhorn. I was involved in an accident that tweaked the front end a little bit, and the body shop said they could fix it with about 10 hours of rack time. I've always wanted a 4WD Longhorn, so would I be better off finding a regular 4wd chassis that already has the transfer case set up and just cutting that frame and lengthing it 6 ", or straighten mine and then scrounge all the 4wd stuff and put it on that frame? Any insight would be appreciated. I must add that after the accident and illness, I'm kind of limited on what I can physically do, so some will have to be farmed out and some will be done by my kids. Thanks.
Re: Which would be easier, lengthing frame or converting stock to 4wd?
Good question. The 4wd frame will be a lighter weight frame since all Longhorns had 1 ton frames. They never made a 4wd using the 1 ton frame,so not sure what's involved with swapping cross members. That's what I'd be inclined to do "if" the frame wasn't damaged. So,in your case I think I'd stretch a factory 4wd frame. You'd be getting everything you need if you bought a complete rolling frame with transmission,transfer case,and drive shafts.
To bad we r so far apart. I have 69 4x4 frame with a 4spd tranfercase and rear differential all still installed just needs a front diff and driveshaft. Free to good home.
If you can't impress them with your inteligence, dazzle'm with your stupidity 1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe |
