Old 08-29-2012, 01:02 PM   #1
sixysixss
Question about later model wheels
I have a 1966 GMC 3/4 ton. Still has drum brakes all around. I need to get some new wheels. does anyone know if the new style wheels will fit our trucks? Something like this:
New-2011-13-Chevy-Silverado-GMC-Sierra-2500-3500-HD-8-Lug-20-Wheels-Rims-Tires
Or like this:
16-8-Lug-OEM-Duramax-Wheels-Chevy-Silverado-2500HD-GM-Rims-4x4-HD-GMC-Diesel-LT
I'm not buying off of ebay, but just threw those up as examples. Any info you have will be appreciated. Thanks.
Rob
sixysixss is offline   Reply With Quote
Old 08-29-2012, 02:20 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Question about later model wheels
you need to check the rear wheel opening around the axle shaft area. the front should fit fine but the back would be in question.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-29-2012, 06:48 PM   #3
joedoh
joedoh's Avatar
Or like this:
Rob
the first ad pretty clearly says it will only fit the 11-13 models because the pattern has changed. maybe they edited that after you posted the link but my gut says no.
I have seen pictures of the second type on trucks on this forum. that one may be a possibility depending on the center bore size like clyde said.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 08-29-2012, 07:24 PM   #4
sixysixss
Yes, I have found that the 8 lug pattern was changed in 2011. No longer 6.5.
Old 08-29-2012, 07:35 PM   #5
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I would watch your backspacing too. Some of the modern wheels model look fairly flush on the outside and may not fit well. I think old rims like ours need a more centered hub.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
