Old 08-29-2012, 01:34 PM   #1
Michael35p
Break Drum Delima
I have a 66' GMC, and the other day I noticed the brakes weren't doing so well. So I bought new brake shoes 11x2". I pulled the drum off and it had nasty grooves in it. Went to o'reilly's and asked for new drums so I can just replaced the rear end brakes as a whole. Came home and the lug pattern on the new drum was to big, so I went back and compared hub with what they had in stock. As I compared my hub with the new ones I noticed the area where the bolts where was higher that the new ones but not high enough for the others. I have a 6 lug rear end. Does anyone know where I can get new hubs that fit?
Michael35p is offline   Reply With Quote
Old 08-29-2012, 02:22 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Break Drum Delima
here ya go bud!
http://www.classicparts.com/Drums/products/197/
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-29-2012, 02:40 PM   #3
Michael35p
You sir are a life saver. Thanks.
Old 09-05-2012, 02:56 AM   #4
Michael35p
Well that its a no go. I had my rear checked out and it turns out its a rare-ish kind of rear end. It was only used in this particular GMC truck and only for three years so replacements are non-existent. The drum number is 2007 with a leaf spring suspension, unlike the 2005's which are the remakes that you can get almost anywhere. Time to fish myself a rear end.
Old 09-05-2012, 08:14 AM   #5
tincan1966
tincan1966's Avatar
I ran into the same delimna a couple years ago- the front drums were the same as all the 1/2T 2wd, but the rears were maybe 1/2" thicker drum. Endded up having to machine mine, altho I am sure they were thinner than the mfg recommends.
tincan1966 is offline   Reply With Quote
Old 09-05-2012, 09:10 AM   #6
slorio
slorio's Avatar
Michael35P:
Read all about it here:
http://67-72chevytrucks.com/vboard/s...d.php?t=412665
Hope this is helpful.
regards,
Steve
New Orleans
slorio is offline   Reply With Quote
Old 09-05-2012, 06:38 PM   #7
Michael35p
Yeh, my brake drums are beyond the recommendation. So it became illegal to have them turned down. Thanks for all the help.
Old 09-05-2012, 06:40 PM   #8
tincan1966
tincan1966's Avatar
Micheal35p;
I will look around, I have another '66 GMC rear axle, will double check the drums and PM you if anything useable.
Old 09-05-2012, 07:56 PM   #9
gimmy 64
you neede to get 72 blazer 4 wheel drive drums. had the same problem with mine. everybody wants to sell you chevy drums and they are not the same. we have danna 44 rear ends. the blazer drums are wider and work good--50$ at autozone each
gimmy 64 is offline   Reply With Quote
Old 09-05-2012, 09:08 PM   #10
tincan1966
tincan1966's Avatar
Thanks for that info, gimmy64, I never was able to figure out what would interchange.
Old 09-05-2012, 10:03 PM   #11
Michael35p
Just placed an order for the drums. Now I wait. Again, Thanks for everything.
