Old 08-29-2012, 07:52 PM   #1
davepl
davepl's Avatar
How to make tight bends in tube without kinking?
Today all my new hardline material should arrive... I need to do all new brake and fuel lines. The brakes are a mix of 1/4 and 3/16, and the fuel is 3/8.
I ordered stainless so it'll stay looking nice. But in looking at my originals there are a couple of places (like right where the hard line goes to rubber to connect to the fuel pump) where they've got a really tight bend. 3/8 line doubles around in a 180-degree turn with a radius of about 2 inches in one place.
I don't know if the factory used a mandrel, or how they got it that tight. Are there are tips or tricks anyone knows to make a tight bend like that without kinking the tubing?
I've seen tubing with a spring outer wrapper, and I could try to find the spring part and use it just during bending, but not sure if that'd help. I could in theory do it without those tight bends, but I'd like to keep it as close to original as possible.
If you're curious, none of the vendors nor inline tube or classic tube has them for big-block long-horn 3/4 tons, so I'm sort of on my own with this one.
Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-29-2012, 07:59 PM   #2
Dunenutt
Newbee
Dunenutt's Avatar
Re: How to make tight bends in tube without kinking?
These work very well, and bend stainless like butter.
http://www.swagelok.com/search/find_...9-501f774bb60d
Eastwood or some of the other places may have a cheaper version.
Dunenutt is offline   Reply With Quote
Old 08-29-2012, 07:59 PM   #3
wilbilt
wilbilt's Avatar
The springs work to some extent. Tight bends are iffy.
I have heard that filling/packing the line with fine sand can help achieve a tight bend, but I haven't tried it.
1971 GMC C2500 Custom Camper - Second Owner.
350/TH350, Dana 60 Rear.
wilbilt is offline   Reply With Quote
Old 08-29-2012, 08:01 PM   #4
davepl
davepl's Avatar
I was reading a thread on MotoIQ that suggested the sand or baking soda, but no one could seem to figure out how to get it packed in tight enough to do any good. I've seen it done for larger tube, like 3/4, but they packed the tube with sand and then welded the ends shut for the bend...
Old 08-29-2012, 08:22 PM   #5
vidman
vidman's Avatar
If you have a good hand tube bender you can make bends as small as the bender will allow. if i remember right you have to use a 39 degree double flair but someone that bends tube for a living will correct me if i,m wrong..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 08-29-2012, 08:42 PM   #6
AusTx68
AusTx68's Avatar
What about using a 90 degree fitting screwed into the fuel pump with a 3/8 barb on the inlet side. I did something similar when I went all SS with -6 AN hose and fittings.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 08-29-2012, 08:54 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I got this tubing bender off a Mac Tools truck... It bends EZPZ up to 180 degree bends in 1/4" to 1/2" tube. Just happens to be in the same pic as my Flaring Tool Kit.
I made this 3/8" pump to carb fuel line with it...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-29-2012, 09:22 PM   #8
terry b
terry b's Avatar
Nice job man.
terry b is offline   Reply With Quote
Old 08-30-2012, 12:27 AM   #9
bollybib
bollybib's Avatar
I should keep an eye out for a Mac Tools truck.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 08-30-2012, 06:36 AM   #10
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Originally Posted by davepl View Post
I've seen tubing with a spring outer wrapper, and I could try to find the spring part and use it just during bending, but not sure if that'd help. Dave
That's not for bending purposes, it's actually called gravel guard to help protect the line. I buy that in bulk from http://www.classictube.com/
I got all my line, fittings and gravel guard from them for my wrecker project and made my own lines.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 08-30-2012, 11:47 AM   #11
GRX
GRX's Avatar
Glass bead works well for this trick. Smallest I have done is 1/4" tubing. The trick is to make sure both the bead and inside of the tubing is clean & dry.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 08-30-2012, 01:06 PM   #12
tex_waco_usmc
Project Heaven in my 67!!!
I did all my bending with a hand bender that I bought at the local parts store for like $15 and just bent it slow and controlled, never forced anything and it went great without any issues! All my tubes are inline SS tubes!
tex_waco_usmc is offline   Reply With Quote
Old 08-30-2012, 03:08 PM   #13
El Campo
El Campo's Avatar
Thats a nice bender that Gasoline71 has up. I have one of those Eastwood bending pliers and made a 180 that had only a 1 inch radius without kinking. I hope you have a darn good flaring tool! I broke the 1/4" die on even a Rigid 45 degree double flaring tool on the first flare before breaking down and buying a Mastercool hydraulic flaring tool. Stainless is a whole different animal than other materials. Incidentally if you do not have the right tools I will rent you my Mastercool which I have the 45 degree double flare attachments as well as all the 37 degree single AND double flares for also. Plus I have the cutter to cut stainless and all my different benders too. If that helps you out.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 08-30-2012, 04:44 PM   #14
davepl
davepl's Avatar
I have the Mastercool (I think it's also sold at Matco and a couple of other brand names, same tool) hydraulic flaring too. I also picked up the 37 degree dies and cone so I can do AN style stuff on other projects.
If you're making more than one tube in your lifetime, I heartily encourage anyone to get the Mastercool hydraulic flaring tool. I always struggled, especially with larger diameter steel or stainless. With the hydraulic unit I've never failed to make a great fitting, unless I tried something goofy.
Old 08-30-2012, 05:29 PM   #15
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
In-line tube will bend you up a set of lines. The only difference in a longhorn brake line kit and that standard 3/4ton kit for a 2WD truck with leaf spring rear end is the length of the brake line that runs from front to rear of the truck. You send them your original and they will duplicate it. Then they will have an original pattern for future trucks.... WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 08-30-2012, 07:27 PM   #16
davepl
davepl's Avatar
They didn't seem interested, just told me they didn't really have anything for Longhorns, and it took two months to get that answer.
According to their parts listing they have a complete front brake line set for the 3/4 ton, but under their Master Cylinder lines, which are the hard ones, nothing for 3/4 ton.
