08-29-2012, 11:56 PM | #1 |
Got hose? Ls swap lower rad hose
Hi everyone just completed my ls swap on my 69c10. I'm using the stock three core radiator. It has the neck that comes off and angles up at a 45degrees just like the four cores I compared it to. The aluminum adapter is by jags that run. This hose fit like a glove. I also think that since these hoses have enough strait sections after the bends that even if your motor was set back towards the fire wall it will still work.I just wanted to give back to the swappers community as they have provided me with great information. I know there are many options on what people have used, this is what I did. I was lucky to have free rein in the napa/riebies rad hose section and this is what I used. In the first picture I used the adapter on the rightif you carefully measure and cut these hoses the left over pieces are enough for a second.used this protective cover to clean everything up this came on the hoses I purchased.
Posted via Mobile Device |
10-12-2012, 05:29 PM | #2 |
Re: Got hose? Ls swap lower rad hose
Ttt
10-13-2012, 06:24 AM | #3 |
Collector of Projects
10-13-2012, 08:16 PM | #4 |
That's where I got mine their service was quite interesting though.
01-25-2013, 11:14 AM | #5 |
So is that the one I need to order for the steam pipe in the upper hose?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
01-25-2013, 07:23 PM | #6 |
Yes if you choose that route. I just tapped the top of water pump and ran the hose to that.
02-02-2013, 08:10 AM | #7 |
Gates 20931 lower hose
I found this number from another member. Fits right on 3 or 4 core radiator to ls water pump. Posted via Mobile Device |
02-02-2013, 08:46 PM | #8 |
i used a 1" galvanized pipe with a brass nipple, and spliced the upper radiator hose, works great and is hidden nicely under the the cold air intake..
02-03-2013, 10:30 AM | #9 |
Thanks a lot 68fixeruper very good info. Do you know of an upper rad hose thats out there that works well on our trucks?
02-03-2013, 10:35 AM | #10 |
Great info on the hose and adapters!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-03-2013, 11:20 AM | #11 | |
02-03-2013, 03:21 PM | #12 |
A picture would be nice !
02-03-2013, 11:38 PM | #13 |
Nohatch I use 06 Tahoe stretch it over the stock three core rad works perfect
