08-30-2012, 03:50 AM | #1 |
Has anyone put a 383 LT1 in a 65 GMC
I can get my hands on a LT1 fairly cheap, has anyone installed one of these in a 60's GMC? Any tips or info would help
09-02-2012, 12:42 AM | #3 |
Re: Has anyone put a 383 LT1 in a 65 GMC
thanks
09-02-2012, 10:11 AM | #4 |
just ask questions
09-02-2012, 01:25 PM | #5 |
I am in process right now. Should have it in by next weekend. I will have a full write up in my build thread. Of course the engine is no biggie, it bolts like any other small block. Additional things you will need are;
Programmed PCM - remove VATs, EGR, etc and program for what is inside. Harness - either stand alone or rewired factory harness Fuel pump - high pressure fuel pump (45-50 psi) either in tank or external. To go with this you will need a return line to the tank also.
65 short step edited by staff |
