Old 08-30-2012, 04:27 AM   #1
JCD
JCD's Avatar
Truck Just Quit
Jumped in the '72 today and it started right up as usual.. drove about 30 feet in the parking lot.. stopped at the curb to look both ways, and it just died.
No noise, no fanfare.. just died, like it was out of Gas.
I pushed it back to my space, and tried to start it .. it turns over fine, lots of battery .. It was down to a few inches in the tank, but it's always run on less than that..
Just to make sure, I added a few gallons, and put some into a squirt bottle..
A few squirts down the carb (2 barrel) and it roared up and caught for a second or two, then died again.
This happened over and over.. I finally stopped as to not completely drain the battery.
So, I'm getting spark, it's turning over fine, and I have an HEI distributor, that was running fine just moments before.
I have the stock fuel pump, and the lines aren't leaking at all.
My guess is it's getting no fuel.
Either the pump or a clogged filter.
Usually a clogged filter sort of bogs you down in the days or weeks that preclude a shut down..
(Can't lean in far enough to see, I'm on my own, and it's too damned hot during the days)
My question is, can a pump just suddenly go from one second to the next?
All my pump experiences allowed the car to draw fuel once they were running..
And if it's NOT the pump.. anyone got any words of experience wisdom that can point me in the right direction?
J.
1972 Custom Deluxe Highlander C20
1971 Javelin SST New Project
1971 Demon 340
1969 SS El Camino
1968 SS RS 396 Camaro
1967 Barracuda Formula S
1965 140/4sp Corvair Monza Convertible
Sorry, but I don't do Fords.
JCD is offline   Reply With Quote
Old 08-30-2012, 05:18 AM   #2
Roninwolf
Roninwolf's Avatar
Re: Truck Just Quit
replace the pump and the filter
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=531265
72 Cheyenne Super
90 Z71 S.B. 434 C.I. Stroker
78 Camaro Z28 (gave to wife she is restoring it)
Roninwolf is offline   Reply With Quote
Old 08-30-2012, 06:28 AM   #3
Roninwolf
Roninwolf's Avatar
Re: Truck Just Quit
Oh and check any of your old rubber fuel lines the 10% ethanol gas will eat it up to where its clogging stuff up or it colapses.
My build thread
72 Cheyenne Super
Old 08-30-2012, 08:20 AM   #4
cdowns
cdowns's Avatar
Re: Truck Just Quit
i'd take the supply line off the pump and with gascap off blow (lopressure) into the disconnected line to see if it or the intank strainer was clogged// hook up and then try it // if it now works it means you've got the 40years of crap in the tank cloggin things up
