Junior Member
![]() Join Date: Mar 2005
20" chevy take off wheels
Has anyone mounted these wheels to 67-70 original 6 lug set up?
![]() Join Date: May 2007
Re: 20" chevy take off wheels
backspacing /offset would be an issue
LUCKTRUCK ![]() |
Well Drew has it on his 72 Crew Cab, but he is using a late model frame. Dunno how much the backspacing affects the older frame vs the newer ones.
http://67-72chevytrucks.com/vboard/s...26382&page=139
Jason TEAM C10 HOT ROD POWER TOUR
689 Short Step 68 Step Trucks Sold: 70 GMC, 72 K5 Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins |
Junior Member
I like the look on Drew's truck and am aware of offset & lug nut issues but i see quite a few of the later 88 & up wheels on our 67-70's even 8 lug set ups.
Anyone try to mount this particular style wheel? |
67-72 parts collector,…
![]() Join Date: Nov 2002
Center bore of the new wheels to too small also.
Junior Member
Sorry no pix but I recall a really nice lowered silver 67 or 68 SWB for sale somewhere with these on it. Looked better than I thought it would.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
you can use them but you will have to have spacers. 2 or 2.5 inches. probably cost you 120-150 bucks.
#8 | |
Correct me if I'm wrong but I believe the 67-72 6 lugs were 6x5, the new 6 lug Chevy vehicles are 6x5.5? If so then that will be a problem. Posted via Mobile Device
Under Construction* 2011 Chevrolet C1500 | RCSB | 6.7 | 10PSI *Under Construction* 1968 Chevrolet C10 | SWB | 6.3 | 6PSI *Under Construction* 1968 Dodge Coronet 440/ Cloned Super Bee | 7.2 | 14PSI |
Both are 6x5.5.
Here's an old thread,...
http://67-72chevytrucks.com/vboard/s...d.php?t=221042
Hmmmmm, good info and link LoLife, I learn something new everyday.
That makes me wanna put my 6 lug SS wheels on my 68! Aside from the backspace and center hole issues. Posted via Mobile Device
Oooooh, just saw your sig lolife, I will be needing that 67-70 drum to disk info eventually as well, just saved the link, good deal!
#13 |
Junior Member
Thank's to lolife for the link to old thread. I think they look good on our trucks. So bottom line is spacers so grease cap and center hole diameter issues go away.
