Old 08-31-2012, 08:43 AM   #1
jirish09
4 inch or 6 Inch
I have a 1984 gmc K3500. wanting some opinions, i have some 35/12.50/17 nitto mud grapplers. should i do a 4 inch and save $ or just do the 6 inch in case i wanna do bigger tires?
jirish09 is offline   Reply With Quote
Old 08-31-2012, 09:05 AM   #2
riz
Re: 4 inch or 6 Inch
6"..... go big now and never look back.
RIZ
riz is offline   Reply With Quote
Old 08-31-2012, 09:22 AM   #3
82ccshorty
82ccshorty's Avatar
30 inch go big or go home
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 08-31-2012, 09:22 AM   #4
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
The cost difference will probably not be that big between 4 and 6". If you think you may want to go bigger later, now is the time to do it. Although I feel my 4" is right where I want it with my 35x12.50s and don't plan to go any higher on my K30, but it is a DRW.
Why even make them out of spring steel with that much arch? Might as well weld some 2x2 tube to the frame and axle
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 08-31-2012, 11:24 AM   #5
SamMargritz00
SamMargritz00's Avatar
6 inch with 35's. go for the 6 inch, might as well get what you want the first time, saves money in the long run. ive learned that countless times
Blazer Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=483399
SamMargritz00 is offline   Reply With Quote
Old 08-31-2012, 11:41 AM   #6
82ccshorty
82ccshorty's Avatar
Lol I don't know
Old 08-31-2012, 03:21 PM   #7
spencer_41188
spencer_41188's Avatar
go 8.5 lol
http://www.polyperformance.com/shop/...p-p-19164.html just weld it up so you can run the 52" springs
hey its kinda cheap but it will ride good, flex well, and clear some good size tires
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker.
spencer_41188 is offline   Reply With Quote
Old 08-31-2012, 03:52 PM   #8
whiskeydented
whiskeydented's Avatar
I had a 4" in my 78 before I restored it. When I restored it I replaced the 4" lift with a 6" lift. If I had to do it again I would've kept the 4" lift. I had some drive line issues with the 6" lift, for one I had to get a new front driveshaft. The old one wasn't quite long enough. I think you would have plenty of room for 35's with the 4" lift.
whiskeydented is offline   Reply With Quote
