Old 08-31-2012, 09:28 AM   #1
54belair
54belair's Avatar
Changing E Brake
Has anyone changed the ebrake from the pull handle to the later foot pedal?
If so, how difficult is the change, at first thought it seems pretty simple.
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 08-31-2012, 03:43 PM   #2
c1069
c1069's Avatar
Re: Changing E Brake
I saw one thread here but I don't remember Who?
It was easy just cut 69-72 firewall patch fro a donor truck.
Pancho
69 c/10 step side 454/400 with 3.07
c1069 is offline   Reply With Quote
Old 08-31-2012, 04:02 PM   #3
c1069
c1069's Avatar
Got it http://www.classicheartbeat.com/panel_5.htm
Follow page 6 too
Pancho
Old 08-31-2012, 04:27 PM   #4
54belair
54belair's Avatar
Thanks for the link.
On my truck, we've had to cut out both top corners of the firewall due to rust in the tray and air boxes. I havent gotten the truck back yet but Im thinking the hard work may be already done since my doner cab was a 71.
Believe me, the link is correct---this is major surgery.
If it requires more cutting and welding on the firewall (other than minor hole filling or relocation---its a job that wont get done. Pulling the old ebrake handle is still "doable".
thanks again,,
1968 short stepside
1966 mustang
1966 chevelle ss
My Build Thread
Old 09-02-2012, 01:47 PM   #5
OldCreek
OldCreek's Avatar
I cheated:
I welded up the original wiring harness hole. Then, I cut the new wiring harness hole and parking brake hole. Then, I cut a little bit off the front of the pb pedal mount and bent down a small portion of the lip of the dash. I drilled the mounting holes front and back and painted it up.
You have to cut a little off the front of the mount since you don't have the indention in the firewall to set it back a little.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 09-02-2012, 06:05 PM   #6
54belair
54belair's Avatar
Is it sturdy and look good that way?
Im still at a point on the cab where I can weld or make any mod.----Im just not going to tackle the major firewall surgery again.
1968 short stepside
1966 mustang
1966 chevelle ss
My Build Thread
