Old 08-31-2012, 10:47 AM   #1
Smurfeh
Fan Options 84 5.3
Hey guys, just interested to see what some people have done for fan options in their machines. 1984 K5 with a 2007 5.3, I would like to go mechanical, but appearently there was no Mech Fan made for the 5.3. Would the mech fan and clutch from the 6.0 work? Anyways Using the stock rad, what have others done, I'm curious! thank you for your replies!
Smurfeh is offline   Reply With Quote
Old 08-31-2012, 06:32 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Fan Options 84 5.3
weird angle to show it but this is a be-cool radiator with either a be-cool or a flexalite fan (can't remember
if your waterpump snout is long enough to accept the fan clutch and fan, I don't see why it wouldn't work. You may want to build a shroud with a mechanical though.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-31-2012, 06:52 PM   #3
OKGMC4
OKGMC4's Avatar
Not sure if you could swap the pump and/or pully, but the older 5.3 had a mech fan screwed onto the water pump pully. (My 01 did) I threw mine away and installed a two speed electric Tbird fan.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 08-31-2012, 09:39 PM   #4
clinebarger
ALL 99-04 truck 5.3's had a clutch fan....Newer trucks still have the threaded hub for the fan clutch.
I use a clutch fan whenever possible. And I think the shroud fills the space between the radiator & engine nicely.
clinebarger is offline   Reply With Quote
Old 09-05-2012, 12:39 PM   #5
Oilbrnr
Oilbrnr's Avatar
H-Matic, is that a squarebody radiator and fan shroud pictured there?
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 09-05-2012, 12:47 PM   #6
Smurfeh
OilBrnr
It sure is..
Old 09-05-2012, 05:24 PM   #7
Oilbrnr
Oilbrnr's Avatar
Interesting. It looks from that angle as though the fan would be too far forward towards the radiator to make the shroud as effective as it should be. ie the fan should be about half in, half out as you look straight across the rear opening...
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 09-05-2012, 05:24 PM   #8
clinebarger
Yes.
Old 09-05-2012, 05:47 PM   #9
clinebarger
The fans not half way out, But is out a little, Cools great & have no A/C head pressure problems.
99-04 trucks have the fan tucked in the shroud from the factory.
Old 09-05-2012, 07:04 PM   #10
Oilbrnr
Oilbrnr's Avatar
Since I have a Dmax LLY over-heater, I've been down the road of all the things that can effect the stack, and I remember several 'heated' debates over on The Diesel Place regarding fan placement. Too far in or out has a impact on efficiency. I'm more worried about the A/C performance here in Phx., probably like you are too!!
What is the hose from? Also a later model square?
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 09-05-2012, 07:36 PM   #11
clinebarger
Upper & Lower radiator hoses are from the 04 Chevy the engine & trans is from.
I was under the assumption the 04/05 LLY had to small of a radiator.
Old 09-05-2012, 08:52 PM   #12
Oilbrnr
Oilbrnr's Avatar
For the most part, you are correct, but there were many changes that GM did to the LBZ to help relieve the issue.
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 09-19-2012, 03:18 PM   #13
nacho55
Oilbrnr
Not to change topics and thread jack too much but i have an 05 lly and mine runs great and doesnt overheat like ive heard of some of them, have you changed out your Turbo mouthpiece to the newer LBZ one, that helps out with lots of problems, i even picked up an easy 1 MPG just from that mod, and it really runs with a the turbo back exhaust.
just something to think about if your still having problems, and i am down here in the valley too, and tow with it and what not,
nacho55 is offline   Reply With Quote
