Old 09-01-2012, 01:01 PM   #1
Grouten
1988 Crew Cab 1 Ton
Look what I brought home...
1988 K(V?)30 Crew Cab, 6.2l diesel, Turbo 400, Dana 60 front
Long ago it was an Air Force truck,then a maintenance truck, now its mine
Needs some work, but looking through here will certainly help, and already has, the fuel gauge didnt work on the ride home but have since fixed it.
Plans for it include:
A visor
Maybe a flat bed (this bed is pretty beat up)
Finding another diesel tank so it can have dual tanks again
Possibly painting it camo
Some rust on the drivers rocker and floor board that Ill have to fix then hopefully rhinoline the interior of the cab
Suburban or tahoe leather seats for it
and of course a turbo or two...
... and a bunch of other stuff i havnt found out is wrong/needs attention
and its already earning its keep... heh
Grouten is offline   Reply With Quote
Old 09-01-2012, 01:06 PM   #2
AntiGov
AntiGov's Avatar
Re: 1988 Crew Cab 1 Ton
nice truck ...and a fun project...
88 3+3 454 400 205 410 drw to srw still in pieces
90 3+3 350 400 205 410 srw
84 1/2 ton lb 6.2 4x4 parts truck
AntiGov is offline   Reply With Quote
Old 09-01-2012, 01:07 PM   #3
Grouten
more pics
ill take some more of the interior and engine at some point
only 9200lb gvrw though
Old 09-01-2012, 01:43 PM   #4
Grouten
moar!
the dash is pretty cracked... i think ill just flatten it out and fiberglass over it
might put a radio in it as it doesnt have one now
and it had a plow on it, they put the pump on the tranny hump, cant say its a bad idea, but well see
that engine will look nice with a couple turbos sticking off it...
and thanks! ive been looking for a crew for a while and am glad to finally have found one that wasnt too beat
Old 09-01-2012, 01:47 PM   #5
Grouten
rust... grrrrr
thats the worst of it... so it should be easy to fix
Old 09-01-2012, 03:14 PM   #6
Car'n'Guitars
Car'n'Guitars's Avatar
Cool truck, I wish that was all the rust my truck had.
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 09-02-2012, 05:45 PM   #7
Grouten
http://www.masterseriesct.com/home.html
anyone have any experience with this product?
i found it researching por15 on a different part of this forum and it seems to work pretty well, this distributor is also a stones throw away from where i live... itll most likely end up being what i use to fix the dreaded rust. i understand that it sticks to bare metal much better than por15 and acts as its own primer?
any opinions/knowledge would be appreciated
That hack job below is gonna get all new sheet metal
YAY!
Old 10-18-2012, 09:04 PM   #8
Grouten
Havnt posted in a while, but Ive got some stuff done
found a visor and mounted it
painted it camo (yeaaaa spray paint!)
i might have to respray the brown, it seems a bit light
took the fuel tank from a k10 that i have mostly disassembled at my buddies shop, drained it and will paint and install asap
i found some 37 inch humvee tires mounted on good rims that i hope to install soon, probably putting a hockey puck lift under the spring packs and body mounts, as i have over 9000 laying around. The tires should then fit with minor fender trimming.
Old 10-18-2012, 11:27 PM   #9
wwj75c30
wwj75c30's Avatar
hocky pucks dont sound very safe.. id make some 2" lift shackles and add blocks out back look on craigslist for used lift springs
75 c30 silverado drw 454/th400hd d70 soon to have d60 up front
73 c20 custom deluxe sm465 14bff parts truck
wwj75c30 is offline   Reply With Quote
Old 10-28-2012, 07:08 PM   #10
Grouten
I hadnt thought about a shackle lift, but that would probably be the best route to go for the suspension. As far as a body lift hockey pucks should be fine, i had friends do it to various other vehicles and theyve held up fine over the years.
Apparently gas and diesel tanks are different, the gas one has a smaller fill hole, so i guess its back to finding a diesel tank to replace the missing one
The PO had just screwed sheetmetal over the hole in the passenger floor board, so the other day I cut it all out and welded in new, and painted it all up nice and pretty, at some point Ill get to the drivers side, its not as bad though. I just need to get more welding wire and cutoff wheels to do it.
should be fun to wheel around in this truck after the hurricane hits this week
Old 11-29-2012, 02:22 AM   #11
Grouten
got the big tires on, no lift, minor fender trimming, if i find a cheap 1 ton lift ill get that sucker on it.
I wanna find a plow blade for it to show my dad how much easier a truck with heat is than a snowblower
cant really see it in the pics but there are dual cb antennas mounted on the front of the bed rails too, I gotta get a good cb, any suggestions?
still have to fix the drivers floor, but its too cold to paint it after welding so thatll have to wait.
there was a bowtie horn button stuck in the seat, thats on the wheel now. Ill get a pic of it later
