Old 09-01-2012, 01:38 PM   #1
1972_Buford
Transmission cross member bolt hole measurements please.
I welded in a new 1/8 steel piece to fix this:
And I am looking for the measurements to drill in the new bolt holes. I initially assumed they would be centered in the mount but didn't want an extra set of holes.
Does anyone have the mount accessible to where they could measure the holes from the top side? The seam from the upper brackets to the holes would be great. Thanks in advance.
1972_Buford is offline   Reply With Quote
Old 09-01-2012, 01:58 PM   #2
1972_Buford
Re: Transmission cross member bolt hole measurements please.
Bad quality, taken with cell phone, but you get the point. Still need to grind a little on it.
Old 09-02-2012, 12:44 AM   #3
1972_Buford
bump, sorry looking for some info this weekend to get this done and up and running.
Old 09-05-2012, 04:16 PM   #4
1972_Buford
Does anyone know if the transmission is centered in the truck?
Old 09-05-2012, 04:23 PM   #5
c1069
c1069's Avatar
looks like 15 3/4 to the first hole and 17 1/4 to second
Pancho
69 c/10 step side 454/400 with 3.07
c1069 is offline   Reply With Quote
Old 09-06-2012, 03:54 AM   #6
1972_Buford
Great thanks. Is that to the center of the bolt holes? Does that look like the two holes are bascially centered??
Old 09-06-2012, 11:05 AM   #7
c1069
c1069's Avatar
Measures are to the center of each hole.
Pancho
Old 09-06-2012, 11:25 AM   #8
1972_Buford
thanks again
