Attempting the "$50 paint job"
After reading all the threads on the internet about the $50 paint job using Rustoleum I figured I'd give it a shot. My paint is beat and I wanted it a different color always so what the hell right?
![]() ![]() ![]() ![]() ![]() ![]() They have a color called "Sand" that's very close to GM Sante Fe tan, which happened to be the color I wanted. Should get started laying down the first layer after lunch. |
Re: Attempting the "$50 paint job"
I painted mine with a roller and brush last fall. The slight texture I got was helpful in hiding some of the body imperfections, since my truck had significant rust beforehand. I did sand the rusted areas and apply a brush-on rust converter. I did not thin the paint at all prior to application, which limited it's self-leveling properties. I see that you are spraying the interior and jambs, guessing your plan is to spray exterior as well? Looks like you have a great start.
I was not able to really apply any wax/sealer as I finished my painting the weekend before the winter weather hit last fall. I would suggest soem type of application once your paint cures, I'm probably going to hit mine with another coat here this fall, and hopefully get that done as well. But overall I was surprised at how well the paint held up even thur our harsh winter months here in Minnesota. EDIT : here's a pic of mine. http://67-72chevytrucks.com/vboard/s...1&postcount=55
TomS. '98 S-10 Blazer 4dr 4wd - 4.3, AT, stock & '85 K-10 w/ 305, 700r4, np208, and RUST! SOLD Dec 2014 Last edited by TDS-MN; 09-01-2012 at 02:30 PM. |
No, gonna roll the exterior due to the said self leveling of the paint. I just figured spraying the interior and jams would be easier.
i have thought about this with my truck. i like sante fe tan, i was going to do cordova brown and a sante fe tan cab top but figured i could do leather brown and white rustolium paint
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
I always use duplicolor. Seems to lay better and doesn't wrinkle itself with multiple coats. Lay down a clear as well so the paint don't oxidize
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
i used duplicolor and some rally wheels. i couldnt find argent silver but i got soem "close enough silver" and it worked great. i didnt have any problems with it and it cured up great
I just sprayed mine this morning with rusto semi-gloss white and it looks good for the first coat. Almost has a pearlish silver thing goin on which makes it look sweet.
Subscribed.
What do your neighbors think about all this lol
bet you they have some questions.] ![]() |
![]() Join Date: Jun 2012
What are you using and what mix ratio are you using to thin out the paint?
![]() Join Date: May 2009
Looks good so far, also thinking about htis for my CC, same color also. My friend at work just did his F@rd van, not sure he thined his, def has a texture, a little to much for me. It kind of reminds me of a refriderator door type texture.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD 84 Chevy K30 CC SRW 55 Chevy 210 2dr post |
#13 |
At first I thought you guys were kidding,,,,till I got to post #9
#14 |
I started this, this weekend as well... mine went on A LOT thicker than that tho lol...
one coat cover mine pretty well... though I mixed it at 4:1 with xylene, I'll sand it down tomorrow then probably do the other coats 3:1 by weight shootin' for a 20/20 finish.. ![]()
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
#15 | ||
Posted via Mobile Device |
#16 |
Just here to tinker
![]() Join Date: Jun 2008
Ha! Awesome. If you check the thread in my sig for my 78, I also used home depot's sand color for my cab. It is very close to the factory buckskin color.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
#17 |
i did this on my truck and boy what a ton of sanding. i have never sanded like that in my life. probably spent 2 weeks sanding so i only did one cycle turned out pretty good
2001 Tahoe 1978 K30 |
#18 | |
![]() ![]() FYI: The hood has a ton of hail damage so I'm skipping it until I find better hood, and the bottom part of the truck will be Dupont bed liner |
#19 | |
#20 |
its green... tho it's a bit darker than what it seems like there..
#21 |
Wow, this is coat 4 and it's really starting to take shape:
![]() There are still some thin spots, tomorrow morning I need to finish coat 4 (it rained shortly pretty heavily during coat 4, NO ILL EFFECTS TO THE PAINT, even though it was wet! This rustoleum is amazing) then wet sand again. I'll keep updating. |
#22 |
how bad is your orange peel? yours look pretty smooth... mines horrible lol
#23 |
It's actually VERY slight. I found a really good technique of applying, I follow the body lines going vertically, make 2 passes over roughly 2ft area. I can see it self leveling and it leaves no lines.
#24 |
What's the recoat time that you are allowing between coats. I have always heard that the window was 30 minutes or then wait 24 hrs. Does mixing the thinner/paint at 50/50 ratio shorten the recoat time between coats?
I am planning on doing the same thing to my truck. I can't afford a $1000 paint job on my work truck. It just needs to be the same color all over. Posted via Mobile Device
1984 C20, 454, 4 speed named "Gold Member" |
#25 |
You guys do realize that rattle cans have no hardeners in the paint,,,,it will scratch and chip extremely easy,,,and has no real UV resistance either. It will fade within a month or two of being in the sun.
I take it this is just a beater? |
