Old Air Product with billet firewall bulkhead connector
Hello, I've ordered an Old Air Product A/C system for my 69, it's the one that allows you to use a billet firewall bulkhead, however I'm having difficulty figuring out how to install the unit inside th cab, and where to mount the bulkhead to get the lines through the firewall. It would be very appreciated if anyone who has done could post some pictures of there setup. Thanks
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges |
Re: Old Air Product with billet firewall bulkhead connector
I have Vintage air so I don't know if this helps or not. Adding the bulkhead fitting was a PITA!
That looks sweet, and appreciate you taking the time to post the photo. Un fortunantly the with the setup I have it looks like to make mine work I will lose the passenger side fresh air vent. The lines coming off the unit point towards the passenger side kick panel on the Old Air unit, and does not leave much room to run the lines
