![]() Join Date: Jan 2002
Sourcing a stall torque converter...
Anyone know a good place to buy a stall torque converter? I need a 2600-2800. Also, when I measured my fly wheel, from bolt hole to bolt hole(straight across) is 11". Is that what size I go by when I buy one. My 496 stroker transformation is well under way and this is one of the last things I need
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
Re: Sourcing a stall torque converter...
I loved the TCI converter I had behind the big-block in my old Chevelle. I live in Ar and they are made in MS so it is only a couple hunred miles so if I needed a change I could pull it and they could cut it open andtigthen or loosen depeneding on what you needed. But that was a race applacation. Anyway, the TCI stuff always worked good for me and they are willing to help you decide what is best for you and your truck depending on cam, compression, rear gear and total weight. Also don't forget to put a good cooler on the truck to help keep the trans happy. Jim
#3 | ||
"I ain't nobody, dork."
Uh... almost any aftermarket parts outlet? Jegs? Summit Racing? Even on ebay?
You will need the TC that fits your transmission. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
I called Hughes and they recommend this one for my specs. http://www.summitracing.com/parts/HUP-GM30/. Funny thing is they are in Arizona and I am in Arizona, but it was cheaper to buy from Summit.
Thats a loose converter for such a big engine?
Junior Member
![]() Join Date: Mar 2009
Circle D torque converter. They will build what you need.
