I swapped cabs on my 77 to a cab from an 87 automatic now Im having an issue with the Z-Bar fitting and where to drill a hole for the clutch rod. Im wondering if anyone has done this and how to solve this problem. I understand that the 87 models had a hydro clutch, but did the cab change in that area too. I hope this can be sorted out any help will be appreciated.
Re: Clutch Pedal HELP
I guess if anyone has a picture of the hole in the firewall that would help out a bunch
there should be a dimple right under the pinch weld, right under the steering column. punch it out with a 2" hole saw
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
Thanks mongoose, is there anyone out there with a picture of this area?
| Bookmarks |
