Old 09-01-2012, 09:14 PM   #1
Jemo
Share what you do before first drive!
My truck has been 95% finished for several months, I'm just lacking motivation. All I have left to do is bleed the brakes and check why the lights aren't working with the new harness. I'm also having a problem with the brake pedal not returning, it just stays depressed. (need a stronger return spring?) I think I keep putting it off because I'm honestly pretty nervous on the first drive. I'm especially nervous the transmission TV cable may not be adjusted right.
Anyways, what do you all do before you take a long time project on the road for the first time?? I'm going to focus tomorrow and Labor Day on getting this truck finished.
'59 Big Window Fleetside
Jemo is offline   Reply With Quote
Old 09-01-2012, 09:19 PM   #2
pinecrest
pinecrest's Avatar
Re: Share what you do before first drive!
DUUUUUUUUUUUUDE!!!!!!...... git out thar and git er going!!!
pinecrest is offline   Reply With Quote
Old 09-01-2012, 09:23 PM   #3
Lextech
Lextech's Avatar
Pray, And take your cell phone with you.
Jeff
Lextech is offline   Reply With Quote
Old 09-01-2012, 09:28 PM   #4
LEEVON
Moderator
LEEVON's Avatar
Hook up a pressure gauge to the 700r4 pressure port on the driver's side. Couple rules of thumb; make sure you have 2-3psi at idle, make sure your throttle doesn't bottom out the TV plunger, make sure your plunger returns all the way and make sure your cable doesn't get stuck. If you take pressure reading that's peace of mind.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-01-2012, 11:12 PM   #5
Chevette
Chevette's Avatar
I usually drink three or four beers and then ask my wife to take it out for the first voyage. Why should I risk my own life!
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 09-02-2012, 12:06 AM   #6
meter swinger
meter swinger's Avatar
I do a similar ritual, but with vodka, scotch or tequila. LOL
meter swinger is offline   Reply With Quote
Old 09-02-2012, 06:34 AM   #7
1project2many
Start it. I've found it's much easier to enjoy the ride if they're running.
Seriously, check all the fluids, ensure no leaks, quick visual for anything out of place, then hop in and enjoy the ride. Small trip first, under a mile, and make sure someone's close by in case you have a problem. Throw some screwdrivers and pliers on the floor, maybe some vital fluids, and take a short spin.
1project2many is offline   Reply With Quote
Old 09-02-2012, 11:06 AM   #8
mknittle
mknittle's Avatar
I drive up the driveway around a big oak tree acouple times and back to the shop. check for leaks athen go around the block shut it off and look for problems. then go for a longer ride.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 09-02-2012, 11:55 AM   #9
va4cqd
i would start by making sure you have properly working brakes
va4cqd is offline   Reply With Quote
Old 09-02-2012, 01:14 PM   #10
_Ogre
_Ogre's Avatar
get the brakes bled and working right and drive it!
shop air compressor timer
Old 09-02-2012, 01:57 PM   #11
Denee007
Denee007's Avatar
ON my '67 Mustang build, had to run of course, and brakes had to work(doah!)! It is very nerve racking! Then to build up confidence in it, I drive it to Moms(not far away), then to car gatherings(not too far away). I just worry if it were to stall, like at a red light~ people may stare and point! I don't have much confidence. I'm sure the same will go for my '59 Apache~some day ; )
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
