09-01-2012, 10:58 PM | #1 |
sbc a/c question
Am looking at some sbc a/c brackets. seller (not on this site) has them listed as 67-72 fitment "for short water pump".
so, if for the short pump, wouldn't these just be for 67-68 only? i.e. didn't chevy switch to the long water pump on all 69 models? Wouldn't 69 and up bracekts be different? Thanks in advance. |
09-01-2012, 11:40 PM | #2 |
Re: sbc a/c question
When GM did the big switch I thought trucks and 'vettts kept the short pump for a while longer at least through '72. Here is a very complicated illustration for you to check p/n applications against. Dig out your parts manual or use the online wiki.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
09-01-2012, 11:44 PM | #3 |
My original 72 350 has a short waterpump.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
09-01-2012, 11:46 PM | #4 |
My '71 has a short pump. Alternator on drivers side.
1971 GMC C2500 Custom Camper - Second Owner. 350/TH350, Dana 60 Rear. |
09-02-2012, 12:14 AM | #5 |
ok - thanks all, that makes sense - I saw some other material that stated vette/trucks common thru 75 and that they were not the same as the passenger cars. So, that would make sense. Good to know - short pump on the 350 thru 72 at least.
Thanks! |
09-02-2012, 12:16 AM | #6 |
73 was the first year of lwp on trucks. Vette used swp until C4 in 84.
09-02-2012, 12:21 AM | #7 |
excellent! thanks - that clears up what I read about the vette thing now too.
You all rock. |
