05-25-2003, 07:27 PM | #1 |
drag it like you stole it
cure to hinge problem on layed out trucks.
the hinges are off 90's model Buick LeSabre. i have about 5 hours of time in this setup and it looks killer. here are some pics.
negative camber //LA\\ |
05-25-2003, 07:29 PM | #2 |
05-25-2003, 07:30 PM | #3 |
05-25-2003, 07:32 PM | #4 |
05-25-2003, 07:32 PM | #5 |
05-25-2003, 07:57 PM | #6 |
Robert Olson Transport
that was a good idea and it looks pretty good too...i may try this on one of my 73-87 style rides
05-25-2003, 08:09 PM | #7 |
Thats pretty cool, did it take long to install? How much work?
05-25-2003, 08:41 PM | #8 |
KEEP ON TRUCKING
thats sweet
72 cheyenne 2wd lwb 71 k20 sons bassett va |
05-25-2003, 09:15 PM | #9 |
Where's my beer?
That looks great man, good job!, just one question, how do you pop the hood open?
Also, how much does the hood rub the grille? I noticed those rags between the bottom of the hood and the grille.
Paul How do you make the invisible, visible?.........You take it away. Last edited by chevy_fatman; 05-25-2003 at 09:17 PM. |
05-25-2003, 09:20 PM | #10 | |
Seņor Member
Looks good! I spent a while in the garage this evening working on hinges as well... only I was shaving the hinge springs in favor of gas struts. I only got one side done-- it needs a rework on the lower bracket and then I'll post some pics. The struts I used are in the book as '94 Plymouth Laser hatch struts. They were $15/each at AutoZone and have a lifetime warranty. With only one strut and zero springs, it was able to hold the hood wherever I moved it to. With both struts in place I suspect it will go ahead and push the hood open when I pop the latch. Kenneth
05-25-2003, 09:59 PM | #11 |
the hood latches in the stock assembly, the hinge pulls the hood foward then up and over. i have to modify the stops on the hinge to keep it from sitting on the grille. it barely skims it.
05-26-2003, 12:00 AM | #12 |
97' Tahoe 2dr/2wd
cool,
i like the "all out" custom trucks on this site. tommie |
05-26-2003, 01:13 AM | #13 |
COOL
THAT IS COOL! HOW DOES THE BACK STAY DOWN? IS THERE SOME KIND OF CATCH THAT BOTH SIDES SLIDE IN AND OUT OF?
05-26-2003, 02:37 AM | #14 |
I dont understand that, does the hood come up. Like raise, and then swing out over top of the grill and stuff? Are those all stock parts, just modified to fit on your application? I was wanting to try this mod, and wondered if there was a kit or all custom. Thanks.
Brandon |
05-26-2003, 02:38 AM | #15 |
Oh, btw, why'z it up on blocks?
Brandon |
05-26-2003, 03:03 AM | #16 |
PROJECT 7DEUCE
Sweet all I need is a buick part's car...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-26-2003, 04:19 AM | #17 |
ok , how much do YOU sell the kit for ???????
LOL
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction). Progress on truck so far (follow link): http://67-72chevytrucks.com/vboard/s...ad.php?t=51051 and stage 2 http://67-72chevytrucks.com/vboard/s...ad.php?t=58132 ~ "Why couldn't you have just put the bunny back in the box?" ~ |
05-26-2003, 06:23 PM | #18 |
i have a total of $30 in the setup. and that was the hinges at a local scrap yard. only other parts i used was some 2" angle iron and some 3/8" flat bar. the hood in the rear is held down with a bungee cord for now. i need to fab some catches for it. but that shouldnt be a problem.
somebody will be marketing this soon..heh
05-26-2003, 09:06 PM | #19 |
67-72 Addict!
lotik, that is awesome!!!. I have also seen this done with older Saab 900 hood hardware. I like the Buick idea better though.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
05-26-2003, 09:30 PM | #20 | |
Thats just prime!
*69 GMC short bed stepside with a wimpy six that can barely pull itself. *99 Chevrolet Camaro Z-28 1 Bad 5.7ltr LS1 |
05-27-2003, 08:40 AM | #21 |
Lotik: what about using the pins like they do on race cars to remove the hoods fast
I think that might look good
05-27-2003, 11:08 AM | #22 |
Post Whore
That is awesome - you sure do some nice work.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
05-27-2003, 11:38 AM | #23 |
SKINNY TIRES RULE!
That is GREAT! I don't know if it is different mounting than the '90's LaSabre, but my parents have a '88 LaSabre an the hood opens the same way. You obviously spent a lot of time figuring out how that was going to work, but it looks like it was time well spent!!!!
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
05-27-2003, 11:51 AM | #24 |
i wasn't sure on the years of the lesabre. but the ones that tilt forward work. =)
05-27-2003, 12:04 PM | #25 |
yeah, my first car was an '89 Lesabre and it did that, only Buicks did it. as i remember there were little wheels on the back of the hood that went into tracks that were attached to the fender, and when you pushed the wheels back all the way it would catch. I remember when you would hit the hood release, the front would come up a little, and you had to pull it up some, then lift the back end of the hood so it cleared the grille. that setup looks real trick, good luck!
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
