Old 09-02-2012, 01:09 PM   #1
T.N. Stroker
T.N. Stroker's Avatar
cooling Help Needed...
Cooling help needed..! I have a 1970 gmc with a 383 stroker with very close to 500 hp. I'm running a TCI Street Fighter 700R4 trans. I have a 3 core rad that measures 28" x 18.5" with trans cooler mounted in front coming through Rad first. I have a 16" flex fan with shroud. I discovered to day that I have been running with no thermostat when I was attempting to replace it. I installed an 180 degree thermostat an im still idling at 230 degrees but highway temp is 190 degrees. I'm thinking I need electric puller fans unsure what cfm, I don't know. Any and all is appreciated, Thanks..!
T.N. Stroker is offline   Reply With Quote
Old 09-02-2012, 05:58 PM   #2
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
Re: cooling Help Needed...
I am running a 406 with close to 550 horses and i run 180 even in 100 degree weather. I have an electric fan also but never hardly use it. Couple questions for you. Are you running a fan shroud? Are you running a aluminum radiator?
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 09-02-2012, 06:05 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I would start with a stock clutch fan and a shroud.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-02-2012, 06:08 PM   #4
T.N. Stroker
I am using a shroud and I am not using an aluminum but it is a 3 core. The flex fan is only 16"...
Old 09-04-2012, 08:50 PM   #5
T.N. Stroker
What do you guys think the optimum operating temp should be..?
Old 09-04-2012, 09:14 PM   #6
69GWC
I would stick a 18" clutch fan on it myself I would think that would pull alot more air in then what you have on it now.
69GWC is offline   Reply With Quote
Old 09-05-2012, 12:51 AM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
This is what I would do. With all the power you're making, you might also need a 4-row radiator. But try a better fan first. The only time my truck ever ran hot was when I had a flex fan.
I would expect to run from 200 to 210 degrees at idle, maybe a bit more but that's about the max for what I'd consider ideal.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 09-05-2012, 05:20 AM   #8
Xeen
Xeen's Avatar
I agree with Stocker about the radiator.
However anytime you are trying to put horsepower to the ground you want to get rid of parasitics on your engine so an electric fan setup is always the best option if you have the cash.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-05-2012, 06:35 AM   #9
T.N. Stroker
Thanks for the input guys..! I have a dual 13.5" Flex-A-Lite 4600 cfm on the way... I will update..
Old 09-05-2012, 09:04 AM   #10
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Get rid of that Flex fan. Get rid of it.
Tom Vogel is offline   Reply With Quote
Old 09-10-2012, 12:41 PM   #11
T.N. Stroker
Electric Fans done the trick. Idling at 190 and all is well..! Thanks..
Old 09-11-2012, 03:56 PM   #12
hayhauler71
hayhauler71's Avatar
Have a part number on the fan and how about some pics thanks
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 09-14-2012, 12:08 AM   #13
T.N. Stroker
, "FLX-298" in Summit. I will post pics later, I need to take some...
Old 09-17-2012, 04:33 PM   #14
T.N. Stroker
I can't seem to upload the pics from a mobile device and its the only access to the web at the moment. Will keep trying.
