Old 09-02-2012, 03:24 PM   #1
ssapach
ssapach's Avatar
Frame Differences
I did a little searching for other threads on the topic, but I wasn't finding the answers to the question I have.
I have access to a 1981 GMC 3/4 ton 4x4 that is in relatively good shape for it's age and location. The rear end is a 14-bolt SF axle but the truck has 8-lug hubs all around.
Would this be a plain old 3/4 ton frame or is there a "light duty" 3/4 ton and a "heavy duty" 3/4 ton truck of this style?
My understanding is that there are differences in the material thicknesses between 1/2, 3/4 or 1 ton frames. I could also do a bit of measuring on it to find out for sure, but I don't actually know the differences between the frames.
ssapach is offline   Reply With Quote
Old 09-02-2012, 05:48 PM   #2
frog210
Re: Frame Differences
if i remeber correctly from a previous post yes
i have a heavy duty half ton
so there probably is a heavy and light duty too...
frog210 is offline   Reply With Quote
Old 09-02-2012, 10:12 PM   #3
Roanoker494
I have always been under the impression that a light duty 3/4 ton came with a "standard" type rear end and the heavy duty trucks had the full float rear. I have also been lead to believe that all GMC trucks came with the heavy duty package.
Roanoker494 is offline   Reply With Quote
Old 09-02-2012, 11:57 PM   #4
hatzie
Moderator
hatzie's Avatar
Look at this thread in the FAQ.
http://67-72chevytrucks.com/vboard/s...d.php?t=382332
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 09-03-2012, 05:10 AM   #5
andrewmp6
From what i read the 1/2 and 3/4 is the same but the 3/4 has more crossmember tie ins.The 1 ton frame is thicker then the rest.As far as i remember light duty and heavy duty was more the springs nothing about the frame.
andrewmp6 is offline   Reply With Quote
Old 09-03-2012, 09:26 AM   #6
ssapach
ssapach's Avatar
Thanks for the info everyone!
Old 09-03-2012, 11:43 AM   #7
Desert1957
Desert1957's Avatar
This is true EXCEPT for the 3/4 ton "Camper Special" ask me how I know?
I purchased my 83 camper special 3/4 ton with the idea of upgrading my 1987 1/2 ton. Well to my surprise the 3/4 to frame was quite a bit thicker everywhere I measured, long story short I wound up rebuilding the 3/4 ton an having 3 pickup trucks. It is a very touchy subject at my house currently.
Desert
Desert1957 is offline   Reply With Quote
Old 09-03-2012, 10:21 PM   #8
Your41Plague12
Your41Plague12's Avatar
The 1/2 and 3/4 ton frames have the same outside dimensions, the only thing that differs is the thickness of the metal. The 1 ton frames are 2 inches taller. The light and heavy duty 3/4 tons have the same frames, the difference is in the springs. All 80's 3/4 tons should have had a SF 14 bolt from the factory. What you have is factory, from what it sounds like. They quit using the FF 14 bolts in 3/4 tons in the late 70's some time, IIRC.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 09-03-2012, 10:33 PM   #9
Desert1957
Desert1957's Avatar
I have worked on two other 3/4 ton trucks that had frame thickness like my 1987 1/2 ton. They were not "Camper Special" optioned trucks, I wonder why the differences? One of the trucks is the original owner, so I know it hasn't be modified.
Desert
Old 09-04-2012, 11:10 AM   #10
ssapach
ssapach's Avatar
This I did not know.
I kind of figured they were similar to the GMT400 trucks, where you could have a 14-bolt SF or FF depending on the GVWR of the vehicle.
Again, thanks for the info!
Old 09-04-2012, 11:58 AM   #11
hatzie
Moderator
hatzie's Avatar
You were right. 14 bolt FF vs SF is GVWR dependent just like the GMT400. GM modified the axle design in 1986 to make the drums removable without pulling the hubs... it's still a 14bolt FF axle. HD 3/4 ton trucks like the camper specials could have FF axles. LD 1tons could have SF axles.
