09-02-2012, 05:51 PM | #1 |
Transmission help
Pulled my 307 and saginaw 3 speed out of my 68. Can't get the bellhousing and tranny apart from engine. Searched the posts and tried everything suggested,still no luck. Any help would be appreciated. This engine swap is already turned into a nightmare.
Thanks, Dave
68 C-10 Custom LWB 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America |
09-02-2012, 06:44 PM | #2 |
Re: Transmission help
6 bell housing bolts and the lower cover that cover the flywheel must first be removed or the flywheel will keep the whole thing on.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
09-02-2012, 07:21 PM | #3 |
Housing looks like this and the trans. just bolts up to the back. You can pull the front lower shield and and seperate the trans. and housing together from the block or pull the trans. from the housing (four bolts), then pull the housing from the block.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
09-02-2012, 08:40 PM | #4 |
Thanks,guys. It was the bell housing cover. Four hours for two bolts. DUH!!!!
Thanks again
