14 bolt tear down
I finally found me a good 14 bolt full floater to install in my 70 4x4. I want to go thru the brakes and also install new wheel cylinders before putting it in my truck. I have the axles out but I can't get the spindle nuts off, I have the special socket with the 6 tangs but it won't budge even with an impact or a breaker bar and pipe. Don't know if I've overlooked something or what?
Posted via Mobile Device |
Grease Monkey
Re: 14 bolt tear down
There is a lock washer with tabs that you have to bend up out of the way. Take some brake cleaner to get the grease out of the way so you can see the tabs. Once you get those tabs out of the way, the nut will unscrew. Good Luck. Let us know if you need anything else.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
#3 | |
ok i feel like a dummy, im not seeing the washer and the nut wont budge at all. going to take another stab at it in the morning
Grease Monkey
take a look at this write up, hope this helps
http://www.pirate4x4.com/tech/billav...ble/index.html
Got it now! I couldn't see the key last night and I was figuring there were 2 nuts holding the hub on but guess there's just the one spindle nut.
