Old 09-02-2012, 09:00 PM   #1
72chevyk10
I built it
72chevyk10's Avatar
after market lockout hubs
if i were to replace the factory "blue cap" hubs what brand do i want to get? warn, milemarker, etc..? and what is the diffrence between a "preimum" vs a "standard" hub? looking for simple and easy to work on. my bro just got a f#@d with warn hubs. and they are a lot more simple to pull apart then mine. im pretty religious about keeping it greased up and just lookin to simplify it. also not in a big hurry to swap them out. just wanting to know whats what about them.
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 09-02-2012, 09:14 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: after market lockout hubs
I've heard good and bad about warn and mile marker. The differeance between preimum and std is strength. What kind of wheeling are you planning on doing? How hard are you on your truck? Keep in mind that you hubs are known to break under extreme stress, but I think of it as a failure point. I'd rather break ujoints and hubs than axle shafts.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 09-02-2012, 10:18 PM   #3
72chevyk10
I built it
72chevyk10's Avatar
nothin tooo hard for wheelin. just the occasional muddin and the kinda rough winters last few years up here. no rock crawlin or anything like that. ive never had a issue with the factory hubs cept all the little springs in them..
Old 09-02-2012, 10:29 PM   #4
wilkin250r
wilkin250r's Avatar
I'm not an expert, but I was looking at a few hubs the other day and I got the impression that the difference between "standard" and "premium" is the construction of the hub itself. The standard hubs use a plastic rotation knob for selection, the premium uses a metal knob, often with a stainless steel or brass plating. The websites seemed to indicate that the locking mechanism was nearly identical, and thus both the standard and premium have a lifetime warrenty.
Maybe there is something better about the premium, like an extra seal or something to give it more longevity, but I didn't get the impression there was a tremendous strength difference between the two.
I could easily be wrong, however.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 09-03-2012, 08:53 AM   #5
I've never heard anything bad about Warn hubs. The premiums are better than the Spicers that came on these trucks. They use bronze(I think) in place of plastic. Other modern companies are good,but I'd go with Warn since there are a name from back then (way before).
