Old 05-25-2003, 09:20 PM   #1
shortbed70
shortbed70's Avatar
Hesitation and rough idle
The truck runs good down the highway but has a rough idle. I just changed plugs but this did no good. Also my edelbrock carb stumbles off idle. Please give advise to help me find the problem quickly. The 1&7 and 4&6 header tubes dont gut hot after idling for 2 min. Whats the deal? 350 motor stock.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 05-25-2003, 09:24 PM   #2
knucklebuster
Failure is NOT an option!
knucklebuster's Avatar
sounds like a timing problem.Do you have hei?
House payment or truck parts?????.........why does life have to be so complicated?
1969 Chevy Shortbed Fleetside
1969 Camaro ps pb a/c(drove in high school now it's just a yard ornament,but it's next on the list for resto)
1990 Ni$$an hardbody( daily beater that has been really beaten!)
1999 Grand Am GT(wifes ride...never buy a pontiac!!Trust Me)
knucklebuster is offline   Reply With Quote
Old 05-25-2003, 09:42 PM   #3
ddsmith
Glowing since 1978
ddsmith's Avatar
Is this a dual plane setup? It sounds like you have the one plane running rich causing low temps on the headers feed from this plane. I would suggest removing the air cleaner and start the engine then look into the air horn and see if one side of the carb is flowing liquid gas into the manifold. It may be the idle mixture screw causing that side to run rich.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 05-26-2003, 12:04 AM   #4
shortbed70
shortbed70's Avatar
yes it does have hei and a duel plane intake so tomarrow I'll mess with the mix alittle.
Troy
Big Red Dog build
Old 05-26-2003, 01:07 AM   #5
COBALT
COBALT's Avatar
Improper metering may be your problem. I have stock metering rods and jets in my new 1406 and I've adjusted everything including timing. My next thing is to go one step leaner both on idle and cruise for the meters and jets.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 05-26-2003, 01:42 PM   #6
shortbed70
shortbed70's Avatar
I got to looking and at idle the carb1406 on the pass. side it drips fuel. How can I correct this? I've got 3 1406 carbs but 2 have brocken base plates. Can I swap the top of another on to the one thats on the truck now?
Troy
Big Red Dog build
