Old 09-02-2012, 11:09 PM   #1
rsmarr1982
rsmarr1982's Avatar
lets see if i got what it takes!
this my 69 c10 i bought it for $400 over a year ago and let it sit till this past week. ive never welded in body panels before but im gonna give it a try . the under side looks great except floor panels cause it was oil sprayed. the fenders and inner fender where shot but i already had those laying around. i got a 72 402 from a friend i plan to use with the 3 on the tree set up till i can afford a 5 speed. with my beautiful wife mandy allowing alot of extra weekend time with it i hope to get it looking good. wish me luck
1969 chevy c10 lwb stepside 250 6 3 ott
1971 chevy c10 lwb 250 6 with power steering 3 ott
1972 chevy k20 4x4 350/TH350 automatic
1978 chevy Malibu 4dr 305 2bbl (all original)
1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver)
rsmarr1982 is offline   Reply With Quote
Old 09-19-2012, 12:13 AM   #2
rsmarr1982
rsmarr1982's Avatar
Re: lets see if i got what it takes!
what i thought was gonna be a simple fix turned out to be a little bit more involved. the rust never seemed to stop! this was my first attempt at welding sheetmetal . i was using .025 mild steel wire any one think i should try a diffrent wire . i was burning through at first with the welder turned all the way down but after turning up gas i had more luck. whats the gap between panels i should have? is about the gap of a cutting wheel a good gap?
Old 12-27-2012, 12:20 AM   #3
Bomp
Bomp's Avatar
Nice start. Keep it up.
When my wife lets me play in the shop for long extended amounts of time I take her out to her favorite place to eat. hint hint
On welding sheet metal I use .023 solid core wire in my little Lincoln sp100(more info in vid on my thread) with 75-25 mix.
There are other members you can see, RexDodge is a real good source along with many others.
Remember, take your time and go slow so as you don't warp the sheet metal.
watchin'
Bomp is offline   Reply With Quote
Old 12-27-2012, 09:55 AM   #4
sgaylord
Project collector
sgaylord's Avatar
Bomp is right. Take your time. Practice on some scrap pieces welding at all angles (horizontal, vertical, overhead) till you get a good feel for it. Don't try to run a bead, just tack a inch apart and jump around when the heat dissipates. Good luck!
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel
Jezebel 3.0 NEW!!!
2020 GMC 3500 Denali Duramax
2016 Harley Street Glide CVO
Roll Tide!
sgaylord is offline   Reply With Quote
Old 01-05-2013, 07:40 PM   #5
rsmarr1982
rsmarr1982's Avatar
i found a 4x4 frame to put my body on . i got a real nice a/c cab id rather put on the 2wd frame
Old 01-05-2013, 07:43 PM   #6
rsmarr1982
rsmarr1982's Avatar
another
Old 01-05-2013, 08:00 PM   #7
Bomp
Bomp's Avatar
See your diggin into the trucks but I forgot to ask what ya got in mind. Daily driver, moderate custom, Full blown radical custom????
Old 01-05-2013, 10:40 PM   #8
rsmarr1982
rsmarr1982's Avatar
with the 4x4 im hoping for a daily driver . im sure i prolly wont get the body work perfect since this is my first serious go at it .
Old 03-25-2013, 02:18 PM   #9
72chevynoob
Looks like a good start! Is it gonna end up lifted, or just stock height?
Justin
69 lwb project: http://67-72chevytrucks.com/vboard/s...d.php?t=558011
72chevynoob is offline   Reply With Quote
Old 03-26-2013, 11:55 PM   #10
rsmarr1982
rsmarr1982's Avatar
im gonna leave it stock . i wanna be able to use it to tow or haul whatever my little ranger cant handle.
Old 06-19-2013, 01:02 AM   #11
70LonghornCST
Moderator
70LonghornCST's Avatar
Keep it up. "Learn by Doing" is the way to go. You're off to a great start. Subscribed.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
