![]() Join Date: Dec 2004
4x4 front axle drum to disc
is there any kit out there that will let me change my drums on the front to disc or should i just look for a whole new axle for the front of my 70 k5
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
Re: 4x4 front axle drum to disc
I just went through this. I couldn't find a kit so swapped in a ten bolt from an 84 that I bought for 50 bucks.
Posted via Mobile Device |
Rollin in my K5 toaster
Find yourself a junk yard Dana 44 with disks. That is the cheapest "Kit" you will find. Be sure to snag the Brake Proportioning Valve too. noco-k5's ten bolt is stronger though. Was the ten bolt a direct bolt in noco?
if i could only find a disc front end for 50 bucks,,thats the tricky part..lol
Doubt you'll find a complete disc front end for $50
![]() You could try your local pick-a-part as they are relatively cheap if you don't mind pulling it yourself. Finding a complete dana 44 front isn't all that hard to do. Disc became standard on these things starting in 72. Even $150-$200 would be cheap in my opinion for a complete front diff with disc, and a worthwhile swap. I recently bought front and rear diffs from a 78 complete with 3.73's, posi, all new front suspension pieces complete for $500. They are out there. |
thats what i was figuring..my dad recently bought a 83 4x4 to cut in half for a trailer so i will see if i can get that one
![]() Join Date: Jan 2000
Swapping in a later disc axle is the easiest. Make sure the ratio is the same and you will need to replace the proportioning valve and master cylinder and front brake lines.
70 Jimmy 4x4 71 GMC 2500 Too bad stupidity isn't painful |
i have a bunch of 80s front ends i would sell for 50$ if they went to good use but ..you may want to measure the spring distance before you buy one from an 80s because the frame is a diff width.i tryed it once and didnt work out in that case .it came from an 86 blazer.
Chris Heinz |
![]() Join Date: Jun 2012
I just finished converting my 69 blazer from drum to disc brakes a couple of hours ago. I picked up a 72 blazer dana 44 that was shot for a 100.00 bill. I kept my dana since it was recently rebuilt, so i had to change every thing from the knuckles out (72 disc parts) and keep everything from the knuckles in(69 parts). Had to install a new propotioning valve and new 72 mastercylinder. I also had to plum in seperate front brake lines since the original drums fed off of a single tee'ed line. It was a lot of work and trial and error, but after my 1st test drive tonight i am wearing a big grin from ear to ear. Disc brakes are worth the trouble in my book. I SPENT ABOUT 600.00 IN ALL, BUT I BOUGHT NEW ROTORS,CALIPERS,SPINDAL BEARINGS,HUB BEARINGS,SEALS,BRAKE HOSES,PROPORTION VALVE,MASTERCYLINDER,AND BREAK LINES.
im not worried about the work,,its all a bunch of work
