Old 09-03-2012, 01:21 AM   #1
'82 steppin
'82 steppin's Avatar
Show me your fuel cell
Im about to remove my dual tanks in my '82 shortbed and want to run one tank between the chassis in the rear and the filler shows from the bed wood and I need some idea's and pictures if possible
'82 steppin is offline   Reply With Quote
Old 09-03-2012, 02:41 AM   #2
Mykk
Re: Show me your fuel cell
Sorry, not an 73-87 but in my '04. You should be able to do similar.
Mykk is offline   Reply With Quote
Old 09-03-2012, 04:38 AM   #3
bowtiemanchevyman
bowtiemanchevyman's Avatar
the best thing to do is go get a tank and all the hard wear off a blazer or suburban. that way you get what u need and u can see how it is done.
bowtiemanchevyman is offline   Reply With Quote
Old 09-03-2012, 09:32 AM   #4
bigblock73
yeller
bigblock73's Avatar
Here is mine
http://www.73-87.com/7387garage/chas...ellinstall.htm
bigblock73 is offline   Reply With Quote
Old 09-03-2012, 10:16 AM   #5
'82 steppin
Mykk damn you got one big cell there and thanks guys thats what I wanted to do so so I guess I will take the measurments tomorrow and order the cell
Old 09-03-2012, 04:31 PM   #6
INSIDIOUS '86
INSIDIOUS '86's Avatar
Here's mine
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-03-2012, 04:35 PM   #7
Goldfinger
Goldfinger's Avatar
That fuel cell isn't big enough, better upgrade to a keg.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 09-03-2012, 06:38 PM   #8
bowtiemanchevyman
if u want a big fuel cell some suburbans had a 45 gallon tank. if that the size you looking for. you can get on out of at a junk yard and get all the hard wear and mounting brackets you will need. u can also take pic of how it is mounted in befor u pull it out.
Old 09-03-2012, 07:45 PM   #9
'82 steppin
I dont need that much I guess a 22-25 gal is more than enough
Old 09-04-2012, 12:17 AM   #10
bowtiemanchevyman
then you would go with a blazers gas tank they have like a 32 is the smallest i think
Old 09-04-2012, 02:05 AM   #11
'82 steppin
I will go with one of the aftermarket gas tank with foam and sender I had enough of metal gas tank gets rusted so fast cause of the humidity over here and if I get stock tank I need to sump it so I can save up time and headache and just go with race gas tank and call it a day
Old 09-04-2012, 03:04 AM   #12
74 stepside
74 stepside's Avatar
Suburban tanks will not fit on a short bed truck. Blazer tanks will fit. They come in 25 and 31 gallons.
74 stepside is offline   Reply With Quote
Old 09-04-2012, 03:08 AM   #13
74 stepside
Here is my RCI 16 gallon plastic cell inside its metal box. Its an option for RCI.
Old 09-08-2012, 03:35 PM   #14
Mykk
Mykk damn you got one big cell there...
Summit brand 20gal with foam
Old 10-18-2012, 12:30 AM   #15
bntmotorcycles
I'm looking for someone who might have 45 gal. fuel tank for a suburban. These were made back in th early 70's. Big made of heavy guage steel and held up with 4 long bolt though the plywood floor.
bntmotorcycles is offline   Reply With Quote
Old 10-18-2012, 10:12 AM   #16
motornut
78K & 79C Jimmys
motornut's Avatar
don't know if it will help,I just put a 25 in the 79
size is 28X28X11 deep measured through the sender hole
in one shot you can see the slope from the top to the sides
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 10-18-2012, 07:41 PM   #17
383tbi
Any of you guys with tanks relocated between the rails running in tank pumps?
383tbi is offline   Reply With Quote
Old 10-18-2012, 08:09 PM   #18
Firebirdjones
Yup, I use a custom built 37 gallon with an in tank sump that holds a 340 LPH walbro pump. Tank is from NWP. Works like a champ.
Hang on and I'll see if I have a picture.
Firebirdjones is offline   Reply With Quote
Old 10-18-2012, 08:20 PM   #19
Firebirdjones
Here you go, my pics usually don't stay up for more than a day.
Picture of the behemoth in the paint booth to give you an idea of the size
Fuel pump and fuel sending unit are in and ready...
Here is a side shot I had. You can see how well that thing tucks up in the back. Now I only have to stop at the gas station once every two weeks (it's a daily driver), love it, and great on long road trips.
Old 10-18-2012, 11:09 PM   #20
383tbi
That is one big tank
Old 10-18-2012, 11:18 PM   #21
camaro_red
camaro_red's Avatar
Mine..Stainless with sump, running twin Aeromotive A-1000 through twin 1/2" stainless lines with return.
____
______//__{\_____
,/_(O)__/____/_(O)_/
camaro_red is offline   Reply With Quote
Old 10-18-2012, 11:34 PM   #22
Firebirdjones
It's heavy even without gas in it, glad someone invented transmission jacks
Old 10-19-2012, 09:16 AM   #23
383tbi
What does nip stand for?
Old 10-19-2012, 09:36 AM   #24
Firebirdjones
Ooops, I said NWP and I should have said NWMP which stands for North West Metal Products. They are up in the Washington state area. I'd put a link up but don't know of that's allowed.
If you google it they have a website that lists all their applications. They make auxilary and stock replacement (but oversized) gas tanks for alot of different applications, blazers, trucks, burbs, broncos, you name it. Super nice people to deal with, they are car people just like us.
Can make them out of any material you wish, but Galvanized (which is what I bought) is their most popular as it's cheaper to manufacture and won't rust. He's been making them for over 30 years and told me he does that blazer tank I bought about 2-3 times a month. I didn't think there were that many 69-72 blazers running around
