Old 09-03-2012, 01:12 PM   #1
RPIcka
Shackle Flip HELP
I bought a shackle flip kit from Offroad Designs and shortly after I saw a pic of a guys '72 K-20 lifted with the same kit and the rear wheels looked like they sat out of center in the wheel wells. Is this what I should expect? Does anyone have any pics of their lifted 67-72 with the 4" lift kit?
RPIcka is offline   Reply With Quote
Old 09-03-2012, 02:20 PM   #2
SunSoaked
SunSoaked's Avatar
Re: Shackle Flip HELP
Let me guess-they sit forward of center now? If you only raise the rear mounting point and the spring remains the same lenght it has to move forward. The only way to correct it is to relocate the front brackets rearward, use longer springs, or use off-center blocks (they make em in 1 inch). Keep in mind when you compress the suspension, the leaves get longer and move rearward.
SunSoaked is offline   Reply With Quote
Old 09-03-2012, 02:24 PM   #3
RPIcka
Whats the best way to go?
Old 09-03-2012, 09:10 PM   #4
SunSoaked
SunSoaked's Avatar
I just put a 14bolt under my 69. I used a u-bolt "flip kit" from ORD that puts the u-bolt threaded end "up" instead of down. It swaps the square ubolts for the round ones. The important thing in your case is the u bolt plate has a long notch in it instead of just a hole in the center. This allows you to move the axle fwd or back about an inch. You should get it where you want it before you get the driveshaft made just in case it comes up a little short. The pumpkin is larger on the 14 so you should be ok. I hope I didn't confuse you. Maybe some of the "experts" on here have a better way. Here's some photos of what I'm talking about.
Old 09-03-2012, 09:22 PM   #5
obijuan
search "zero rate"
obijuan is offline   Reply With Quote
Old 09-03-2012, 09:25 PM   #6
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Zero rate or mark and drill the axle perch on the axle 1" forward.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 09-03-2012, 09:28 PM   #7
RPIcka
I'm not sure what zero rate means for me.
Old 09-03-2012, 09:41 PM   #8
obijuan
learn about it, see if its right for you.
Old 09-03-2012, 09:45 PM   #9
RPIcka
So I will get 5" of lift in the rear, what about the front?
Old 09-04-2012, 08:29 PM   #10
mrdana60
I got some zero rate blocks new. I would sell for 35 sshipped.
mrdana60 is offline   Reply With Quote
Old 09-04-2012, 08:32 PM   #11
RPIcka
from ORD? how many? What do I need to do to the front leafs to get the extra inch or does it matter?
Old 09-04-2012, 08:37 PM   #12
mrdana60
Yes I have a pair that would work for the rear. I would put them on and see if you can tell a difference. What size springs you got? I could make you some longer front shackles if it sits unlevel.
Old 09-04-2012, 08:48 PM   #13
RPIcka
I got ORD heavy duty front shackles which are 1/2" longer so I might be getting close. I'll pm you my info.
Old 09-09-2012, 11:06 PM   #14
Mr. 250r
Mr. 250r's Avatar
zero rates
http://offroaddesign.com/catalog/Zero%20Rates.htm
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 09-09-2012, 11:15 PM   #15
RPIcka
Originally Posted by Mr. 250r View Post
front and rear? I'm not sure if I can have blocks in the front legally unless zero rates arent considered blocks
Old 09-09-2012, 11:47 PM   #16
Mr. 250r
Mr. 250r's Avatar
Those are for the rear which i thought we were talking about, as for front blocks i have seen them but basically no one recommends them
2003 1500 Silverado
Old 09-09-2012, 11:50 PM   #17
RPIcka
i have 4" leaves in the front and a shackle flip in the rear which gives me 4". To alleviate the wheels being off center in the wheel wells someone suggested ORD zero rates as they can adjust for 1' or 1.5" movement. That would bring me to 5" in the rear, I just don't want my rear end sitting higher than the front.
Old 09-10-2012, 02:43 AM   #18
Mr. 250r
Mr. 250r's Avatar
So that would make your rear end sit 1 inch taller than the front....? that to me is like seeing the difference in a 37in and a 38in tire, its basically not see able lol but everyone wants something different i prefer my trucks sit like factory where the back is higher so when you put weight on it the truck then sits level
2003 1500 Silverado
Old 09-10-2012, 07:25 PM   #19
obijuan
it will look ass low to me with 4" all the way around. also zero rates arent blocks because the bolt to the spring and act just like another leaf, but dont change the rate. i.e. zero rate.
