Axle Shaft Length 65-66
Looking to order a set of axle shafts. On the website I am looking at they offer a direct replacement for 65-69 at 30.5 inches long. I thought 67-69 were wider by an inch and a half total. Am I thinking of a different year range?
Re: Axle Shaft Length 65-66
i think that they changed when they brought in disc brake and then changed again in 73
ron |
So does that mean first year of discs were 1970?
Posted via Mobile Device |
![]() Join Date: May 2012
Bill, I sent you a PM about the axles.
1962 Impala SS 383 stroker Tremec TKO 600 Black 1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black 2003 100th Anniversary Road King Classic Silver Black |
60-66 Nut
![]() ![]() Join Date: Mar 2007
The axle length for the '63 to early '70 12 bolt is 30.5". In late 1970 when GM went wider with the rear differential, the length changed to 31.25". This length axle was used up thru 1987 in the C and K series, and thru '91 in the R and V series. Disc brakes were first available in the 2wd trucks in the 1971 model year. In the K series they were an option in as early as 1969.
Thanks guys.
