Old 09-03-2012, 06:29 PM   #1
Matt Cramer
What's the trick to pulling the instrument cluster?
So, I've got a '72 Chevy with what I'm pretty sure is a bad gas gauge. Changed the sending unit and it went from no fuel reading to reading 1/4 tank when it's full. I tried removing the instrument cluster. Got the six bolts and the two that hold the frame under the steering column out. Removed the bezels on the washer and light switches. Disconnected the speedometer cable and unplugged the wire connector. And - it wouldn't come out. Not more than about two inches, and I couldn't pull it the rest of the way. Is there a trick? Something I have to do to drop the steering column, for example? (Had to drop the column on a Dodge Dart, for example.) What am I missing?
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 09-03-2012, 06:32 PM   #2
rob32472
Re: What's the trick to pulling the instrument cluster?
oil line? drop the column down a little?
rob32472 is offline   Reply With Quote
Old 09-03-2012, 06:32 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
You will have to drop the steering column. Then you will have to remove the oil pressure gauge feed line. I believe it requires a 1/4" or 5/16" end wrench.
WIDESIDE72 is offline   Reply With Quote
Old 09-03-2012, 10:21 PM   #4
1972RedNeck
1972RedNeck's Avatar
I have pulled quite a few clusters and NEVER had to drop a column.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 09-04-2012, 10:26 AM   #5
hatred
hatred's Avatar
Never had to drop mine either...
05 QSM GTO - M6, Corsa, King Springs
70 SWB CST - 350/Auto, Foose 18/17
I upset whiners too....
hatred is offline   Reply With Quote
Old 09-04-2012, 10:39 AM   #6
Coley
Coley's Avatar
Smile Re: What's the trick to pulling the instrument cluster?
If you aren't deal with removing or installing a tach dash you may not have to drop the column. (Note: dropping the column an inch of two definitely makes the entire job easier and keeps the steering column top paint finish from getting scratched up during the process).
Do you have an update for us on whether or not you got this thing out?
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 09-04-2012, 12:39 PM   #7
mrein3
mrein3's Avatar
Coley
Yup. I never had to drop the steering column either - until I installed a tach in my cluster.
You need to remove the oil line if you have an oil pressure gauge. You also need to remove the speedo cable from the speedometer.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 09-03-2012, 06:34 PM   #8
LEEVON
Moderator
LEEVON's Avatar
I've somehow wedged it out of there before without dropping the steering column years ago, but I wouldn't try that again at the risk of tearing stuff up. Remove the column to bezel grommet cover plate (2 screws). Then the under-dash plate (4 bolts, 9/16 head). Then the column strap (2 bolts, 9/16 head). The column will drop down far enough to pull the cluster out.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-03-2012, 07:55 PM   #9
AirSpeed
AirSpeed's Avatar
You shouldn't have to drop the column at all, I've taken the instrument panel out of all my trucks and never had to drop the column. You will need to remove the oil pressure line, speedo cable, harness connection etc. Slide the rubber grommet up the steering column a bit. Did you remove the headlight knob? If not it's simple to do, there's a little button on top of the switch you have to push while pulling the knob out. You should then be able to pull the top of the panel out a bit to get the rear panel of the cluster to clear the dash and pull it straight out. It should come out fairly easy.
AirSpeed is offline   Reply With Quote
Old 09-03-2012, 08:04 PM   #10
LEEVON
Moderator
LEEVON's Avatar
I fought with it less than a week ago, for whatever reason the top of the cluster wouldn't clear the dash...now way no how. I jimmied with it for 30 minutes before giving up and dropping the column. Sounds like the OP is having the same problem.
Old 09-03-2012, 08:05 PM   #11
Tinkermc
when I pulled mine I did not remove the column but that little button mentioned was hard 4 me to reach.
Tinkermc is offline   Reply With Quote
Old 09-04-2012, 01:59 PM   #12
leddzepp
Moderator
leddzepp's Avatar
I always drop the column because it takes a whopping 2 minutes and makes the job a whole lot easier.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 09-04-2012, 05:33 PM   #13
Square_78
Square_78's Avatar
I like this answer the best.
Square_78 is offline   Reply With Quote
Old 09-04-2012, 06:32 PM   #14
AirSpeed
AirSpeed's Avatar
Seeing how many have had troubles removing the cluster reminds me of similar issues removing the heater motor box without messing with the hood hinge. I wonder if it depends on who was on duty during assembly? I wonder if some columns are mounted tighter than others, I didn't even know there was a problem getting them out. Same with the heater box, seems a lot of people have to remove or loosen the hood hinge to get it out, I've done three of them and they alway slide right out.
Old 09-04-2012, 06:59 PM   #15
19seventeeCustom
done it both ways a few times, only drop the column now. lol
and if you do forget the OP guage the cluster won't budge at all!!
19seventeeCustom is offline   Reply With Quote
Old 09-05-2012, 12:13 AM   #16
Chvy2NV
Is removing the whole cluster necessary to change out the bulbs?
Chvy2NV is offline   Reply With Quote
Old 09-05-2012, 12:31 AM   #17
Coley
Coley's Avatar
No...you should be able to reach up behind and undo the bulbs without removing the cluster.
Coley
2000 Dodge Ram 1500
Old 09-05-2012, 12:40 AM   #18
Chvy2NV
You mean like from underneath the dash? Thanks!!
Coley
Old 09-05-2012, 09:11 AM   #19
yuccales
yuccales's Avatar
The trick to removing the cluster is having a helper!
yuccales is offline   Reply With Quote
Old 09-05-2012, 09:39 AM   #20
DevilDog Aggie
DevilDog Aggie's Avatar
Love it!!!! Looks like one of my 3 helpers! :-)
Rob
'72 Chevy C-10 - 350-5.7/TH350/PS/PB/AC
Build Thread - http://67-72chevytrucks.com/vboard/s...87#post5503187
Semper Fi and Gig'em Aggies!
DevilDog Aggie is offline   Reply With Quote
Old 09-16-2012, 09:05 PM   #21
weever82
weever82's Avatar
Bahaha. That made me smile from ear to ear thinking of my old dog... he was the exact same way... good ol' lazy bones... Thanks for the pic!
Weev-
Weev-
Life's tough...... It's even tougher when your stupid - John Wayne
weever82 is offline   Reply With Quote
Old 09-16-2012, 01:58 PM   #22
Matt Cramer
Thanks to all who responded! I got the instrument cluster out successfully by dropping the steering column, and the new gas gauge is reading fine!
Matt Cramer
4.8 LS build thread
Old 09-16-2012, 02:41 PM   #23
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
You didn't mention taking the oil line loose, I was just about to comment on that. ..For what its worth, I haven't had to lower my column either. Leddzepp made a good point. If I ever replace the original cluster for a new one, you can bet I'll be dropping the column.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
