Old 09-03-2012, 06:35 PM   #1
johndawelder
johndawelder's Avatar
700r4
Do I need a computer to run a 700r4 trans in my truck?
johndawelder is offline   Reply With Quote
Old 09-03-2012, 06:39 PM   #2
Car'n'Guitars
Car'n'Guitars's Avatar
Re: 700r4
I'm pretty positive it depends on the year of the transmission, but more than likely no.
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 09-03-2012, 07:01 PM   #3
heathbirkendahl
Re: 700r4
Great question. Anyone have pain points they can share?
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline   Reply With Quote
Old 09-03-2012, 07:07 PM   #4
johndawelder
Re: 700r4
What about the converter? Is it the same as what I use for a turbo?
Old 09-03-2012, 07:32 PM   #5
68custom396
Re: 700r4
No computer is needed for a 700r and no the converter is not the same as the 350/400 turbo transmissions. It's the 4l60e that needs the computer. As for the pain points there not very strong if you have much more than a stock engine. I'm sure others will have their stories to add
68custom396 is offline   Reply With Quote
Old 09-03-2012, 07:34 PM   #6
Car'n'Guitars
Re: 700r4
Unless you have a built transmission from a raceshop or something. But I think most would agree the TH400 is a really strong good transmission.
Old 09-03-2012, 08:25 PM   #7
piecesparts
Parts and more parts
piecesparts's Avatar
Re: 700r4
You can run a 700 without a computer and a Lockup converter, I have one in my truck that has no Lockup. The valve body has to have some simple mods done to make it happen. However if you want a lockup, then there are kits from B&M and other companies that will let you do that.
Frank
piecesparts is offline   Reply With Quote
Old 09-03-2012, 08:54 PM   #8
67anthony
Re: 700r4
I have one i bought a b&m lock up for summit you to lock up to get the most gas mileage easy to hook up.
67anthony is offline   Reply With Quote
Old 09-03-2012, 09:34 PM   #9
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Re: 700r4
No computer required. I love my 700r4. In our trucks it likes a 3.73+ gear. Had it since '98 & had it rebuilt 1x in that time. I use the Painless Wiring kit for it to run the lock up but there are cheaper solutions out there.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 09-03-2012, 10:11 PM   #10
1972RedNeck
1972RedNeck's Avatar
Re: 700r4
There is a way to make it lockup automatically in the transmission with no electronics required.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 09-04-2012, 12:15 AM   #11
profe56
Re: 700r4
I want to know how 1972 Red Neck'
I've been running my 69 C10 350? 700r4, and 3.42 rear end with no pains with out lock up
profe56 is offline   Reply With Quote
Old 09-04-2012, 01:54 AM   #12
Xeen
Xeen's Avatar
Re: 700r4
Heres what I've learned about running a 700R4 without a computer.
1) You need a 1992 or older 700R4.
2) Instal a Lockup Kit.
3) Instal a adjustable Vacuum switch and a Brake lever switch.
4) Instal a TV cable, and have all components adjusted properly.
5) Enjoy the hell out of Overdrive.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-04-2012, 01:23 PM   #13
profe56
Re: 700r4
A member in this thread mentioned He uses a 400TH I'm going start looking for one, to see how it works.
Just Curiuos.
Old 09-04-2012, 05:57 PM   #14
johndawelder
Re: 700r4
I have a 400TH in my BB 67 already. I was needing the info for a 41 chevy PU with a stock 350.It has a 3:73 gear in it. Thanks guys, I'll take what I need out of this thread. Johndawelder
Old 09-05-2012, 12:16 AM   #15
Chvy2NV
Re: 700r4
Subd
Chvy2NV is offline   Reply With Quote
Old 09-05-2012, 12:43 AM   #16
AusTx68
AusTx68's Avatar
Re: 700r4
I installed the B&M Lockup Kit with no vacuum switch. Works great! Downshifts as needed. The B&M kit allows you to change lockup points on-the-fly. That is a very nice feature. I'm running 4:11 gears and 2000 stall lockup converter. Turns 2300 RPMs at 70 MPH
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 09-05-2012, 01:04 AM   #17
Xeen
Xeen's Avatar
Re: 700r4
Cool, good information I will check that out.
Old 09-04-2012, 06:57 PM   #18
nlped
nlped's Avatar
Re: 700r4
I have a 700r4 out of a '92 (actually denoted as a 4L60...no "e"). I used the overdrive kit from Bowtie overdrives, TV cable & bracket for my quadraBOG, and I converted it from electronic speedo to mechanical speedo in the process. I also added a corvette servo kit to firm up the shifts and I love it! 3.42 gear and a 29" tall tire, it runs out like a champ.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-05-2012, 12:12 PM   #19
Chvy2NV
Re: 700r4
Nice. Gonna look into that
Old 10-31-2012, 08:28 AM   #20
67_ShortFleet
67_ShortFleet's Avatar
Re: 700r4
Great information!
Matt
Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784
My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924
My philosophy on tires is the same as cigarettes. "smoke them if you got them"
HAPPILY DIVORCED!
67_ShortFleet is offline   Reply With Quote
Old 10-31-2012, 08:57 AM   #21
1972SUPERSB
1972SUPERSB's Avatar
Re: 700r4
Question, will the 700R4 fit in my 72 without any fitment issue. Will it clear trans tunnel ok?
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 10-31-2012, 10:29 AM   #22
69gmc292
Re: 700r4
Has anyone used a 700r4 with the TV elimination kit? I see a few kits out now and might try one out on my 6 cylinder.
69gmc292 is offline   Reply With Quote
Old 10-31-2012, 10:45 AM   #23
vin63
It's Better With Nitro
vin63's Avatar
Re: 700r4
I would not recommend a manual valve body just to eliminate the TV cable, if that's what you're leaning to. Adjusting the TV cable is simple and you can use the automatic transmission what it was designed for...as an automatic transmission.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 10-31-2012, 11:01 AM   #24
6772owner
Gearhead
6772owner's Avatar
Re: 700r4
I loved my 700R also, I used the B&M vac switch kit for lock up control and never had a single problem with it. I highly recommend getting the Bowtie Overdrives components for the TV cable, set it how they tell you and enjoy cruising at low RPM. You might also look into the 200R swap, it is easier from what I hear and gear ratios are better, the 1-2 gap on the 700R is a little extreme...
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 10-31-2012, 11:10 AM   #25
Rusbuilt
Rusbuilt's Avatar
Re: 700r4
I have a 700r4 in my c10 as well, 327 V8 with a 3.08 rear and I'm getting almost 25mpg. I have the TCI lock up kit and the only major thing the transmission shop stated was proper adjustment of the detent cable or TV cable. Having the right brackets to attach it to your carb is a must!
Rusbuilt is offline   Reply With Quote
