Old 09-03-2012, 07:02 PM   #1
mater63
mater63's Avatar
Angry 63 doors wont shut
can anyone help me get my doors to shut without SLAMMING them I have changed doors seals 3X i have steele seals on now without the seals in place they shut easy the doors have no shims between the hinges & the cab
mater63 is offline   Reply With Quote
Old 09-03-2012, 07:18 PM   #2
Volvo_Matt
Volvo_Matt's Avatar
Re: 63 doors wont shut
I have the same issue with my '63 on the driver's side. I was thinking about repairing or replacing the door latch. I already adjusted the striker to several different places and found that it did not help, only made it worse.
1963 LWB 350 M-21 4spd comp/edelbrock/holly/LT1 1.94/1.60
Volvo_Matt is offline   Reply With Quote
Old 09-03-2012, 08:13 PM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I think it takes time for the seals to smash down into shape. New seals are always tough.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-03-2012, 08:21 PM   #4
64shortbox
64shortbox's Avatar
As 61 FL Apache said,
I had the same problem on a 62 Pontiac after I put all new seals in. I had to slam both doors toget them to close and slam the trunk HARD usually several times to get it to close. After a month or so they closed very easy like they are supposed to.
64shortbox is offline   Reply With Quote
Old 09-03-2012, 08:56 PM   #5
chainsaw
chainsaw's Avatar
I put on my seals in April and I still have to slam the doors hard To get them to close.
chainsaw is offline   Reply With Quote
Old 09-03-2012, 09:05 PM   #6
mater63
mater63's Avatar
i put the seals in last year & still no luck
Old 09-03-2012, 10:31 PM   #7
chainsaw
chainsaw's Avatar
We might be screwed. Like you, my doors closed very easy without seals. Im out of adjustment room with the new seals.
Old 09-04-2012, 02:52 AM   #8
Volvo_Matt
Volvo_Matt's Avatar
I replaced my door seal 7 years ago and still have to slam the door.
Old 09-04-2012, 07:47 AM   #9
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
try adjusting the lower triangle wedges, I was having problems on a 63, and that helped, didn't have new seals though.
Old 09-04-2012, 08:21 AM   #10
Woogeroo
The nylon bushings in the hinges wear out after 40 years.
Then the door starts to droop and does not line up with the door striker.
You can buy replacement copper bushings to replace 'em. It's a job tho', easier with two folks, especially when putting the door back on.
-W
Woogeroo is offline   Reply With Quote
Old 09-04-2012, 02:43 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I did mine about a month ago while I was painting, and the thickness of replacment seals is definately different.
Put the seals in THEN align your door gaps and bear-claw and striker positions. The aftermarket seals pinch in the FRONT, they end up "rolling" forward and pinching instead of compressing. You need have someone in the truck to hold the seal in place while you close the door firmly. Once its in the correct place, park the truck outside for a day and let the sun beat on it...the rubber needs to break down and be heat cycled before it fully conforms to the shut-points. Leaving my doors closed all the time, and keeping it in the sun when I can, my doors shut firmly after about 3 weeks.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
