Old 09-03-2012, 08:11 PM   #1
8door
Not too old to learn
Cab sound deadening choices.
I have heard a lot about Dynamat, that it is primarily
used as a sound deadener for the sound systems so must be good.
What I want to do is see what else is out there in the market that works, for
road sound as well as heat shield at a "lower cost "
I have never worked with this stuff so have zero knowledge.
What do you all know?
1968 C10 a way to long restoration.
8door is offline   Reply With Quote
Old 09-03-2012, 08:37 PM   #2
Tinkermc
Re: Cab sound deadening choices.
I used it in a truck a while back and it did such a fine job I would have to go back to it
Tinkermc is offline   Reply With Quote
Old 09-03-2012, 08:43 PM   #3
66skylarkpost
66skylarkpost's Avatar
i used a brand called fatmat off ebay. alot cheaper than dynamat yet works just as good , im happY
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 09-03-2012, 09:09 PM   #4
gotchamel
Just did my 69 in Fatmat.Very pleased with it,I too was looking for heat shield as well as sound deadening.I doubled it up against firewall and hump.Take your time and roll it out with alot of pressure.
gotchamel is offline   Reply With Quote
Old 09-03-2012, 09:18 PM   #5
LEX
LEX's Avatar
I used Second Skin in my DD and will probably use it or Fat Mat for my '70. These options are much cheaper than Dynamat.
www.secondskinaudio.com/
LEX is offline   Reply With Quote
Old 09-03-2012, 09:18 PM   #6
69GWC
Do they make any of that in black ?, I have not bought any of that because I know that "chrome" is going to show up bad under my seat.
69GWC is offline   Reply With Quote
Old 09-03-2012, 09:19 PM   #7
LEX
LEX's Avatar
Click my link.
Old 09-03-2012, 09:26 PM   #8
69GWC
Cool thanks a lot.
Old 09-03-2012, 10:14 PM   #9
Lee H
Lee H's Avatar
I have ridden in like cars with fatmat and dynomat. Huge difference, you get what you pay for.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-03-2012, 11:03 PM   #10
72 K20
72 K20's Avatar
Please explain !!
72 K20 is offline   Reply With Quote
Old 09-03-2012, 11:08 PM   #11
FIREBALL
(007) aka Houdini
FIREBALL's Avatar
yeah, i wanna hear about this cause ill be buying some for my truck in the soon future
Live life one day at a time!
FIREBALL is offline   Reply With Quote
Old 09-03-2012, 11:42 PM   #12
SS Tim
SS Tim's Avatar
There is a vendor here on the board hawking his branded Rhinomat. Claims to be just as good and a lot cheaper.
http://67-72chevytrucks.com/vboard/s...d.php?t=538429
SS Tim is offline   Reply With Quote
Old 09-03-2012, 11:54 PM   #13
70cst
70cst's Avatar
I went with B Quiet ...
http://www.b-quiet.com/?googleads
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 09-05-2012, 01:43 PM   #14
8door
Lots of choices . My search just got a little easier.
Old 09-05-2012, 02:09 PM   #15
RRR18
RRR18's Avatar
I have fatmat in the entire cab of my '67 and it works well. It does the job. I have been in cars with dynomat and it seems the same to me. Of course the difference being that one is a car and one is a truck so what difference that makes I dunno. It would be nice to hear earlier poster explain the difference fatmat(less $) vs. dynomat(more $)!!!
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 09-05-2012, 02:24 PM   #16
AirSpeed
AirSpeed's Avatar
I used the remnants of the bed mat in my 69, it's 3/8" rubber. I lined the entire floor with it and glued an 20X24" piece in each door, against the inside of the outer skin. The rubber in the doors made a massive difference, the doors sound very solid when I close them. I have a 3/4" thick mat in the bed of my 72, that alone made a big difference in the over all noise level.
AirSpeed is offline   Reply With Quote
Old 09-05-2012, 02:44 PM   #17
8door
Rubber , sounds like a doable option .
What type of glue did you use to stick it to the doors ?
Old 09-05-2012, 03:24 PM   #18
AirSpeed
AirSpeed's Avatar
I used some construction adhesive, applied it to the rubber then stuck it to the steel, pulled it off letting it tack up then put it back so it would grab without sliding down the door skin. It makes a big difference how the door sounds when I close it, the tinny, hollow sound is gone and now sounds like a solid thud.
Old 09-05-2012, 09:08 PM   #19
Lee H
Lee H's Avatar
There is a product for every budget. You need to use the product you are comfortable with. My friend used dynomat, I used fat mat. I'm really disappointed with the sound suppression of road noise compared to his car. I'll be using dyno at on my next restoration. I liken it to NOS compared to LMC.
Old 09-05-2012, 10:38 PM   #20
BuiltwithIvy
Ive put both in multiple different vehicles depending on customer cost desires, my only suggestion, if you go with fatmat, get a heat gun to help you roll it out because it is not quite as sticky at ambient air temp, but around 130 degrees rolls out really nicely, both I suggest wearing gloves, and buy a pair of scissors that you can throw away afterwards
"To speak of the art of one loom, the art of one river, the art of one tractor, or the art of one automobile is not preposterous; it is to point to the size and importance of the gap between general knowledge and situated knowledge" - James C. Scott
1969 C10 - http://67-72chevytrucks.com/vboard/s...d.php?t=492064
1930 Tudor Sedan
BuiltwithIvy is offline   Reply With Quote
Old 09-05-2012, 10:43 PM   #21
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Cheap stuff off Ebay here.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 09-05-2012, 11:21 PM   #22
coops714x4
coops714x4's Avatar
I used the Thermocustic from Eastwood, VERY happy with the outcome and cost. It was very easy to install, my only complaint is the sheets are a little big but that was easily fixed with a pair of scissors. Coop
1971 K20, Coop's beast (project)
1972 C30 wrecker, "Big Ernest" (SOLD)
1975 K5 Blazer (wife's toy) she got it in the divorce
2014 Street Glide Special
1983 K20 Big Block, auto (work horse)
coops714x4 is offline   Reply With Quote
