05-25-2003, 11:29 PM | #1 |
Repairing 1971 Factory Air System
Does anyone have a faq or maybe a website that has a thorough guide to repairing the heater and A/C in my 1971 C/10 Deluxe? Really need some help.Thanks.
-Never cut what you can untie-H. Thaeau Current Rides: 1971 Chevy C/10 Deluxe Kawasaki Eliminator Bike |
05-26-2003, 12:09 AM | #2 |
I completely reworked mine and if I had the choice to do over I would invest in one of the Vintage Air or Old Air systems.
In the end the cost is about the same and the kits are much more efficient. The kits will add to the value where as a stock unit is just a plus. Have fun
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
05-26-2003, 12:20 AM | #3 |
I just parted out a air truck so let me know if i can help with anyparts!
Things happen for a reason! |
05-26-2003, 04:58 AM | #4 |
i'm gonna switch mine over to the new style a/c that comes on 88-98 chevy/gmc trucks with a serpentine set up too. it won't be as nice as a vintage air or any other aftermarket system but will have a little more for parts availability.
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom |
05-26-2003, 11:20 PM | #5 |
This will get you sstarted in the right direction:
1.remove pass side hood hinge 2.remove bolts and lower rear of inner fender to get to air box bottom bolts. 3.disconnect freon lines at poa valve and expansion valve 4.remove heater hoses 5.disconnect bowden cable to air valve on top of air box 6.disconnect vacuum lines 7.remove glove box liner 8.remove ducts tha are connected to air box 9.remove screws connecting inner box to outer box and seperate them 10. inspect the air box to make certain the airdiverter flapper opens and closes fully If not you will have trouble cooling. Heater air will mix with cold air if not completely sealed off. May be necessary to trim rubber on flapper to make it seal 11.if metal part of air box is rusty drill out rivets and seperate two halves of air box and repair rust. The strip caulk between the air box halves is avail from body shop supply. All Seals and o-ring are avail from LMC Order the (kit) 12replacement heater cores are 1/2 in thinner than OEM but you can heat and bend brackets to fit. Hope this helps.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
