Old 09-04-2012, 02:04 PM   #1
cwolfe
Boiling gas in 66 k10
Hey all, thanks to everyone for posting on the forum, it has saved me more times than I can count, but I can't find an answer for this one. I recently had to replace my exhaust manifold on my 250 chevy K10. The old one had a heat riser that was frozen in the position to direct exhaust away from the intake. The new one I bought has no heat riser valve, so exhaust goes right up to intake manifold. Now when it gets warmed up and I kill it, gas boils in the carb, and it is hard to start. The only fix I can think of is a carb spacer, but I can't seem to find one for my one barrel carb. Anyone know where I can find one. Is this even a reasonable fix? Is there anything else I can do to cool off the carb and/or the intake manifold. Thanks again
cwolfe is offline   Reply With Quote
Old 09-04-2012, 03:50 PM   #2
ky-donzi
Re: Boiling gas in 66 k10
make a wood spacer, use a dense wood like walnut, or cherry. Not pine. Never done it myself but have hear of others doing it.. would be easy to try
ky-donzi is offline   Reply With Quote
Old 09-04-2012, 04:12 PM   #3
forestb
forestb's Avatar
I know they make a heat shield for 350's with a 4 barrel. You might look into something like that.
forestb is offline   Reply With Quote
