So ive decided to bags truck and I've been looking around and found airbag it.com and they have specific applications for a c20. Has anyone ever used their stuff?
1969 chevy camaro Z28 #matchin Factory 4wheel disc 1969 chevy cst10 big block overdrive 5/7 drop dog dishs 1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s 2004 gmc sierra dually 4/4 lowering daily driver |
Re: Air bag help.
In my personal opinion, I would steer clear from airbagit.com, since they have a bad reputation for failing parts and just poor quality. There are a lot of great manufacturers out there that are affordable and worth it in the long run. I personally wouldn't trust my suspension with their products, even if it saved me a few bucks.
Re: Air bag help.
ive vbeen lookin online and ive seen more good reviews then i have bad. i dont want ridetech ive had friends that had their stuff and hated it and they are expensive. theirs a local place here that uses their stuff and seems to be pleased with it. i know they say you get what you pay for but 8000$ from ridetech theirs NO WAY its worth that
Re: Air bag help.
I asked the same question a few weeks ago in reference to Chassis Tech AKA Airbagit.com and received many negative comments. I have a friend who works for a very reputable customer shop in Cali and he suggested *******************. I don't know if they use that there but he has for many years. Most of what he builds are frame layed dualies.
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
Re: Air bag help.
In some cases RideTech (AirRideTech) parts are more expensive than others out there. I was just pointing out that for a little more money than airbagit.com, there are much better choices. Porterbuilt is a good option.
Our Pro2 Air Ride Kit uses Porterbuilt items and comes with everything you need to install air ride on your truck... minus drop spindles, which can be added. The Pro2 systems runs $4359. This kit has tubular a-arms, etc. We also have the Pro1 which is a little cheaper. Pro2 Air Ride Kit You can definitely get a good product for a lot cheaper than $8k. |
Old Heap Driver
Re: Air bag help.
Airbaggit.com is nothing but junk. Ask them why they operate under several different names and several different web addresses.
Airbaggit does indeed get some good reviews, from magazines that have 8-10 pages of advertising from airbaggit. Big bucks will buy you good reviews. It's your money, spend it with whom ever you choose.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
Re: Air bag help.
What would you guys recommend for a 1982 crew cab c20? I need reasonable prices preferably bolt in/ minor modification
Re: Air bag help.
Did you check out the website I suggested?
Re: Air bag help.
Are you keeping 3/4 ton hubs and axles or switching to half ton?
Re: Air bag help.
The Pro1 is a bolt-in application with the exception of the axle brackets. The tough thing on the 73-87's is the leaf springs. It is a good idea switching to a 4-link setup, which usually involves minor welding.
http://www.azproperformance.com/Pro1...-Ride-Kit.html ^^^^ Are you keeping the 3/4T suspension? |
Re: Air bag help.
Yes i am keeping 3/4 ton. Can't stand 5 lug crews they look stupid to me.
Re: Air bag help.
The odd thing ridetech has a c10 and c30 kits but no c20,Is there any way he could use a c10 kit with light mods maybe?
#13 |
Re: Air bag help.
You can go with a 1/2T suspension system, but just need to use a 3/4T drop spindle, etc. Other than that, the bag plates & cups will work since the control arms are the same.
Travis |
#14 |
Re: Air bag help.
Yeah stay away from airbait.com/chassis tech all their products are s**t and their customer service sucks....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
#15 |
Re: Air bag help.
I've got a C30 that I put bags on the front and will be putting an AOL in the rear. I plan to remove atleast half the springs. I made a template and had my upper bag mounts cut out and bent locally and had my lower control arms spring pocket cut out and a flat plate welded in. Cost me less than $180 for everything. I did some research and went with Slam Specialties SS8 Bags. The truck is still being built so I cant tell you about the ride yet. Also I am not trying to lower, just ride improvement.
#16 |
Re: Air bag help.
Could anyone tell me what reasonable price to bag an 86 c10 would be? Would appreciate your input, thanks.
Posted via Mobile Device |
#17 |
Re: Air bag help.
bags, cups and upperplates will be about 200 and fittings and airline and valves could range from 200 to 400 depending on what you do to the front. another 100 for a tank and another 200 for the compressor. bags and brackets for the rear another 200 or so....round about off my head prices. you could do it cheaper like i did in my 86 build but i recommend spending the extra money where i didnt....mine is just a toy i drive every once in a while
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
#18 |
Re: Air bag help.
Do I need to lower my truck first, or can I leave it at the stance its at now
| Bookmarks |
