Old 09-04-2012, 05:45 PM   #1
1986brownjl
HELP...can a 98 z71 vortec go in a 1986 k10
hey my name is jacob and im new to this site. i have a 86 k10 that needs a motor and me and dad just pull his motor out of his 98 z71 that was totalled it has the computer and fuel injucted. im trying to find out if it will work like that in the 86 and if it would what all would i have to do to make it work? any advice would be helpful please
1986brownjl is offline   Reply With Quote
Old 09-04-2012, 09:55 PM   #2
1986brownjl
Re: HELP...can a 98 z71 vortec go in a 1986 k10
please guys i really need help with this, i searched all over the internet all i saw was pictures and videos of them there but nothing on what all i need to work
Old 09-04-2012, 10:01 PM   #3
frog210
yes it will work you just need to get all the computer, wiring,
the computer might need to be flashed to work with your setting
http://www.lt1swap.com/enginepics.htm
you will need a book of the truck so you can know the wiring harness
is it a 5.3 or 5.7
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 09-05-2012, 05:44 AM   #4
1986brownjl
thanks and its a 5.7L.
Old 09-05-2012, 07:48 AM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
You can ditch all the FI stuff. Cheaper too. You can swap in an HEI distributor, dual plane intake, FI pump (if it does not have a mechanical provision), larger cam and keep your tranny. HP -> 300-350 or more with the right cam.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 09-05-2012, 08:07 AM   #6
1974ChevyC10
Overworked and Underlaid
1974ChevyC10's Avatar
gchemist is right take the FI intake,ignition and the remainder of the FI stuff and put a dual plane intake,HEI distributor(just rebuild and re-use yours),re-use your carb after rebuilding it(assuming you have a Q-Jet)or my suggestion is to put an edelbrock carb on it there more reliable imo than a q-jet,i agree with the larger cam suggestion as well.to help offset the cost of the motor and parts swap you could always sell the FI put it on crazylist(craigslist)someone out there who is doing a FI swap may want it.Good luck whatever you do and feel free to ask any questions.
I'd rather push a Chevy than drive a Ford
The Beast-1978 C10 LWB
Red-1978 C10 LWB
(Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012
Gone but will never be forgotten-RIP
(Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012
Taken from us to soon but you will live on in our hearts-RIP
1974ChevyC10 is offline   Reply With Quote
Old 09-05-2012, 08:31 AM   #7
Rogier
Second that, it's what I did for my 81 crew. A lot less hassle and the results can be near as good as EFI with regards to MPG if you take your time to setup the card and ignition.
Rogier is offline   Reply With Quote
Old 09-05-2012, 09:45 AM   #8
Rich84
Rich84's Avatar
You have everything from the donor truck..Use it.
I can't see how it would be cheaper when you have what you need in the donor.
Rich84 is offline   Reply With Quote
Old 09-05-2012, 10:28 AM   #9
Pop's C-10
Pop's C-10's Avatar
True
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 09-05-2012, 10:36 AM   #10
gchemist
gchemist's Avatar
The entire gauge cluster would have to be updated for electronic input. You can buy FI pumps to fit your current gas tanks. You'l need an adaptor to fit tranny to transfer case from www.advanceadaptors.com.
Old 09-05-2012, 12:43 PM   #11
jrblanke
Also, if you choose to go the carb route, you will need to get an intake manifold that will bolt up to the vortec heads.
Not knowing anything about how to convert the truck to FI using the 98 vortec truck, I think the easiest way to get it on the road would probably be to use the long block from the 98, and then buy an intake manifold, and reuse all of the engine parts from the 86 like the carb, distributor, exhaust manifolds, etc.
If I were in your shoes, (an 86 truck with a bad motor, and a 98 parts truck at your disposal), I would read up on how to convert the 86 to fuel injections using the entire 98 vortec engine, computer, trans, etc. It is a much better engine in my opinion. It will just take a little bit of time to figure out, but there is lots of information on this site.
jrblanke is offline   Reply With Quote
Old 09-05-2012, 01:06 PM   #12
gchemist
gchemist's Avatar
Aftermarket stand alone TBI systems are cheap compared to MPFI. Making less than 350 HP makes a TBI easy to add. A stock GM TBI would be easy to add with the correct intake manifold.
Check out this stand alone TBI.
http://www.jegs.com/i/Holley/510/502...oductId=745169
